Timings in RTEMS
Thu Sep 22 12:25:10 UTC 2011
On 09/22/2011 07:18 AM, Oleg Moroz wrote:
> Sorry. I mean some document that contains times what RTEMS needed to
> execute some actions like a context switching, interrupt service or
> something else.
All the timing information that is available can be reproduced
by anyone by running the "tmtests" and "psxtmtests" on the
desired hardware target.
We used to include that in a manual but the burden of
keeping it up to date was too much.  To be sure it was
always right, it had to be regenerated for every target
of interest on every minor release.  Even the times
files in a lot of the BSPs are based upon not current
versions.  They are probably accurate enough but....
If you are can't run the tests on some board comparable
to what you are interested in, then ask on the list.  I
am sure someone will be happy to share.
--joel
>     *From:* Sebastian Huber <sebastian.huber at embedded-brains.de>
>     *To:* rtems-users at rtems.org
>     *Sent:* Thursday, September 22, 2011 4:13 PM
>     *Subject:* Re: Timings in RTEMS
>     On 09/22/2011 02:09 PM, Oleg Moroz wrote:
>     > I'm using the SPARC. I'm not really want see real time of
>     switching. I want to
>     > see something like specification.
>     What do you mean with specification?
>     Sebastian Huber, embedded brains GmbH
>     Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>     Phone  : +49 89 18 90 80 79-6
>     Fax    : +49 89 18 90 80 79-9
>     E-Mail  : sebastian.huber at embedded-brains.de
>     <mailto:sebastian.huber at embedded-brains.de>
>     PGP    : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>     _______________________________________________
>     rtems-users mailing list
>     rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D.             Director of Research&  Development
