RES: Shared library link
Wendell Pereira da Silva
wendell.silva at compsisnet.com.br
Fri Sep 23 12:35:52 UTC 2011
Hi Oleg,
There is a template of a Makefile that you can use to generate a static library in RTEMS_SOURCE/make/Templates/Makefile.lib.
To link you app, just use the -l option of the command line of the gcc/linker.
Hope it helps you.
Att.
Wendell.
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de Oleg Moroz
Enviada em: sexta-feira, 23 de setembro de 2011 07:55
Para: Rtems
Assunto: Shared library link
How can i link my app with shared lib? I need to create a library that contains all standart functions like a prinf puts and addresses of this functions are constant. after this i want to link this library with my executable file that can call funcs from lib. I want get segments from library and append its to my executable file with reallocation addresses to library funcs addresses.
URL: <http://lists.rtems.org/pipermail/users/attachments/20110923/92159eb0/attachment.html>
