compilation error : missing RTEMS_BSP
Ralf Corsepius ralf.corsepius at rtems.org
Wed Sep 28 09:00:35 UTC 2011
On 09/28/2011 09:29 AM, Asma Mehiaoui wrote:
> Hi,
> when i tried to compile an example in testsuites/mptests i had the
> following error: "missing RTEMS_BSP".
> so, Where i can find this library ?
RTEMS_BSP is not a library, it is an environment variable, which either
can be set manually or the configure scripts set.
=> Something is broken in the way you are trying to build RTEMS.
Unfortunately you are not providing sufficient information to be able to
help you.
Ralf
