Run GDB with DDD
Chris Johns
chrisj at rtems.org
Wed Sep 7 00:54:05 UTC 2011
On 5/09/11 9:04 PM, clovis MPassy wrote:
> Hi,
> This is my configuration for RTEMS:
> rtems-4.10.1/configure --target=sparc-rtems4.10 --prefix=$(CROSS_TOOLS)
> --disable-multiprocessing --disable-cxx --enable-tests=samples
> --enable-multilib --enable-posix --enable-networking --enable-ada
> --enable-rtemsbsp="erc32 sis" --enable-rtems-debug
> RTEMS installs withoout errors.
Can you try a full path to configure from the root directory.
