Pin Reading
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Apr 2 13:17:55 UTC 2012
On 04/02/2012 07:09 AM, Binkowski, Cassio wrote:
> Thanks Sebastian.
> However, where do I find such information for the specified BSP?
There is a proposed set of methods in the http://git.rtems.org/multiio/
package. It has been used on a few projects and the API is growing
organically. Functionality is not being added unless there is a project
requiring it and we can define a solution. But for Discrete I/O, I know
there is board independent infrastructure to support waiting for
a pin state change interrupt forever or with timeout. You can poll
discrete in, ADCs, or write DACs.
It includes drivers for a couple of PC-104 multi I/O boards. I am interested
in seeing more feedback so we can have more confidence that it is
offering the right services.
Sebastian is completely correct in that the numbering of discrete I/O
pins, DAC, and ADCs is arbitrary. But if RTEMS provides a standard API
for these capabilities, then you can hide the pin numbers with macros.
--joel
> Cassio
> On Mon, Apr 2, 2012 at 4:16 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 04/01/2012 09:19 PM, Binkowski, Cassio wrote:
> Dear all,
> Forgive my ignorance, but I just want to know how to read pins
> with RTEMS.
> For example, if I want to read a pin in an Arduino I just code
> it like:
> analogRead(pinNumber).
> Is this covered in RTEMS or do I have to read the datasheet
> and make my own code?
> Every BSP handles this differently. Even if we add a
> rtems_read_pin(X), then what means X on BSP 1, 2, or 3?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6 <tel:%2B49%2089%2018%2090%2080%2079-6>
> Fax : +49 89 18 90 80 79-9 <tel:%2B49%2089%2018%2090%2080%2079-9>
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20120402/e51b1e0e/attachment.html>
