how to reduce executable compiled file
Luca Cinquepalmi
cinquepalmi at planetek.it
Tue Apr 3 16:11:24 UTC 2012
In my Makefile I also use these commands:
sparc-rtems-strip $@.exe
sparc-rtems-objcopy --remove-section=.comment $@.exe
but the final .exe file is always large, about 300KB from the original 3MB.
Should I use other commands? Thanks
Il 03/04/2012 18.04, Rhenzo Losso ha scritto:
> Greetings,
> Maybe you can use the sparc-rtems-objdump or sparc-rtems-strip. I'm
> using RTEMS on arm processor (CSN637 port) and I use arm-rtems-objcopy
> to transform the arm.exe into arm.bin. It reduce from 2MB to near 147kB.
> 2012/4/3 Luca Cinquepalmi <cinquepalmi at planetek.it
> <mailto:cinquepalmi at planetek.it>>
> Hi all,
> I'm new of the list and I have a simple question. I compiled a
> simple "Hello World" c code
> with sparc-rtems-gcc, but the generated executable is about 3MB,
> so much for my use...
> I don't know why the executable file is so large... How can I
> reduce its size?
> Thank you
> Luca
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> Rhenzo Losso
> Bacharel em Ciência da Computação - UNESP / São José do Rio Preto
> Instituto Tecnológico de Aeronáutica
> Praça Marechal do Ar Eduardo Gomes, no. 50 - Sala 253 - Projeto ITASAT
> Vila das Acácias
> 12228-900 Sao Jose dos Campos, SP, Brazil
> +55 012 3947-6903 (Sala do ITA)
URL: <http://lists.rtems.org/pipermail/users/attachments/20120403/b83cd75c/attachment.html>
