$(PROJECT_RELEASE)/../lib/librtemscpu.a or $(PROJECT_RELEASE)/lib/librtemscpu.a
    Hill, Jeffrey O
    johill at lanl.gov
    Thu Apr  5 00:33:18 UTC 2012
Hi,
FWIW, on the git latest RTEMS I notice that the net demos application does not build unless I make the attached change. Being an RTEMS nebie, I am guessing that perhaps this isn't the correct way to fix the net demo build?
I also have a related question; I initially jumped to a conclusion that the librtemscpu is dependent only on the CPU, but not in any way on the BSP. However, I notice that many source files in c/src/lib/cpu are including "bsp.h"? So now I am somewhat confused; are these source files including "bsp.h" because they are accessed in c/src/lib/cpu during the build of the bsp library (and presumably become part of a bsp library)?
Thanks for your help,
Jeff
Change to "rtems/c/src/make/compilers/gcc-target-default.cfg"
@@ -175,7 +175,7 @@ LINK_FILES =\
     $(CONSTRUCTOR) \
     $(OBJS) \
     $(PROJECT_RELEASE)/lib/librtemsbsp$(LIBSUFFIX_VA) \
-    $(PROJECT_RELEASE)/lib/librtemscpu$(LIBSUFFIX_VA)
+    $(PROJECT_RELEASE)/../lib/librtemscpu$(LIBSUFFIX_VA)
 LINK_LIBS += $(LD_LIBS)
