RCC toolchain problem with leon2
Daniel Hellstrom daniel at gaisler.com
Fri Apr 20 08:18:34 UTC 2012
Hi,
You can post LEON related questions at the leon_sparc Yahoo group.
Regards,
Daniel Hellstrom
Aeroflex Gaisler
On 04/19/2012 10:53 PM, Joel Sherrill wrote:
> The RCC toolset is supplied by Aeroflex Gaisler.  Those folks are on
> this mailing list but may not see this. If there is an official forum
> for RCC support, you are better off asking this there if you don't
> get an answer quickly.
> On 04/19/2012 11:28 AM, Luca Cinquepalmi wrote:
>> Hi all,
>> I compiled a simple "Hello word" C program with sparc-rtems-gcc v4.10.
>> I tested it with TSIM sparc simulator and it works.
>> I also developed a toolchain to load program on a leon2 board that convert
>> a .exe file into a .hex file but the program doesn't work.
>> The same program, compiled with sparc-elf-gcc and converted with the same
>> toolchain works with no problem.
>> Here's summerized my toolchain:
>> CC = sparc-rtems-gcc
>> CFLAGS = -msoft-float -qleon2 -mcpu=v8
>> LIBS = -lgcc -lm -msoft-float
>> LDFLAGS = -mcpu=v8
>> $(CC) $(LDFLAGS) $(SOURCES) $(LIBS) -o $@.exe
>> cp $@.exe u$@.exe
>> sparc-rtems-objdump -d $@.exe > $(OUTDIR)/$@.disas
>> sparc-rtems-strip $@.exe
>> sparc-rtems-objcopy --remove-section=.comment $@.exe
>> sparc-rtems-objdump -s $@.exe > $@.dat
>> sparc-rtems-size $@.exe
>> Dat2Hex.pl $@.dat text > code.hex
>> Dat2Hex.pl $@.dat data > data.hex
>> cat code.hex data.hex > program.hex
>> I have two question:
>> 1) can the toolchain also be used for sparc-rtems-gcc?
>> 2) shall I necessary use mkprom to create a loadble program or
>> another kind of toolchain can be used?
>> Thank a lot for your answer
>> Luca
> Joel Sherrill, Ph.D.             Director of Research&   Development
> joel.sherrill at OARcorp.com         On-Line Applications Research
>      Support Available             (256) 722-9985
> rtems-users mailing list
> rtems-users at rtems.org
