Makefile with sources from different paths
João Paulo Scalão Martins joaopaulosm at gmail.com
Fri Apr 20 14:39:24 UTC 2012
Hello guys!
I'm using Eclipse to create and manage a RTEMS application. The makefile is
based on the model Makefile.leaf.
The problem is that I have a folder inside the workspace path, with some
source files. I need to keep these files separated, just for a clean
workspace.
This folder is named "modules". When I build the project, the compilation
stops when it start to compile the "modules path" sources. At this point, I
create (manually) a folder named "modules" inside the "o-optimize" folder,
and then I build the system again.
I've tried many modifications in the Makefile code, but it didn't work at
all.
Does anybody know some trick to solve this?
Thanks!
Regards from Brasil,
*Joao Paulo Scalao Martins*
*Controls Group Engineer*
*Brazilian Synchrotron Light Laboratory - LNLS
<http://www.lnls.br>/CNPEM<http://www.cnpem.org.br>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120420/3952699a/attachment.html>
