Supported ARM BSPs
Sun Apr 29 15:03:05 UTC 2012
I don't know what you are trying to do. Buy a board that has. BSP. Pick a BSP with simulator support. Pick one close to a custom board being built. When you count the variants, there are lots of BSPs.
Gedare Bloom <gedare at rtems.org> wrote:
>The boards you listed are available in the development branch of RTEMS
>(git repository head, aka 4.11). So the easiest thing would be to use
>4.11 if that is an option for you. I'm unsure about the bsps available
>in 4.10 without going to look at the source. You can find them in
>c/src/lib/libbsp/arm/ subdirectories. BSP variants are defined in the
>make/custom/*.cfg files within a bsp's subdirectory.
>-Gedare
>On Sun, Apr 29, 2012 at 1:22 AM, Fered <a_Fered at yahoo.com> wrote:
>> I want to prepare a board that RTEMS has a BSP for it. It seems that the
>> website is not reliable!
>> Please tell me if BSP of any Cortex based board is available and how can I use
>> it.
>> Thanks a lot.
>> Fernando Nicodemos wrote:
>>> Dear Fered,
>>> There is also the csb637 bsp which is a variant of csb337.
>>> Unfortunately i did not work with these bsps yet. I tried to find them also
>>> and itsnames but i could not. Maybe they are variants of other bsps but are
>>> not described well in wiki with proper names.
>>> Regards
>>> Em sábado, 28 de abril de 2012, Fered escreveu:
>>> > Hi;
>>> > In RTEMS website, I see following BSPs are impelemented:
>>> >    - NXP LPC17XX (pin compatible to LPC24XX with ARM Cortex-M3 core)
>>> >    - Stellaris Microcontroller LM3S6965
>>> >    - STMicroelectronics STM32 F4
>>> > I work with RTEMS-4.10.2 and only following BSPs are in the source:
>>> > csb336, csb337, edb7312, gba, gp32, nds, rtl22x, rtl22xx_t, smdk2410
>>> > How can I add those 3 BSPs?
>>> > Those 3 items, are names of micro controllers. We have BSP of any board
>>> > that use those micro controllers?
>>> > Thanks
>>> Sent from Gmail Mobile
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
