Supported ARM BSPs
Fered a_Fered at yahoo.com
Mon Apr 30 14:34:19 UTC 2012
Are all available BSPs in the following address?
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm
Thank you.
Sebastian Huber wrote:
> On 30/04/12 05:50, Fered wrote:
> > The problem is which BSPs are actually available?!
> If you want to add a new BSP, please use the Git master:
> The list on the wiki refers to the BSPs available on the Git master.
> > I want to buy a board and I'm not sure which board has a BSP (whithout
> > modification or any additional attempt!).
> http://www.st.com/internet/evalboard/product/252419.jsp
> http://www.embeddedartists.com/products/kits/lpc1788_kit.php
> http://www.embeddedartists.com/products/kits/lpc2478_kit.php
> http://www.embeddedartists.com/products/kits/lpc3250_kit.php
> http://www.phytec.com/products/rdk/ARM-XScale/phyCORE-ARM9-LPC3250.html
> > And I intend to do 2 other works (customize a BSP for my own board and
> > use a simulator) but they are not in priority.
> On ARM several BSPs run on a simulator.  This one uses the ARMv7-M
> architecture:
> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lm3s69xx/README
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
