Configuring for the lm3s69xx BSP does not seem to work
Mon Apr 30 16:30:29 UTC 2012
On 30/04/12 16:45, Peter Dennett wrote:
> But when I:
> ../rtems/configure --enable-rtemsbsp=lm3s69xx --enable-tests=samples
> --disable-posix --target=arm-rtemseabi4.11
> I do not have a lm3s69xx target.
> Other then casual end use I have no GNU automake/configure
> experience.  Where do I start looking?
The BSP name is specified by the *.cfg files.  For the lm3s69xx the BSP
name is "lm3s6965".  This BSP runs only on a simulator currently:
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lm3s69xx/README
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
