how to reduce executable compiled file
Tue Apr 3 16:43:11 UTC 2012
Try sparc-rtems4.xx-size *.exe
The size can vary enormously based upon what you
are doing in application space.
--joel
On 04/03/2012 11:33 AM, Rhenzo Losso wrote:
> I just made this test some right now on BSP SIS.
> sparc-rtems-strip -s executable_name.exe -o strip-executable_name.exe
> It was reduced a lot. from #MB to 140kB. After this I turn into binary.
> sparc-rtems-objcopy -O binary strip-executable_name.exe
> final-binary-name.bin
> 2012/4/3 Luca Cinquepalmi <cinquepalmi at planetek.it
> <mailto:cinquepalmi at planetek.it>>
>     Sorry! I answered in Italian:-)
>     It only reduce my exe file of some hundreds of bytes:-(
>     Il 03/04/2012 18.15, Rhenzo Losso ha scritto:
>>     Try to change some argument o sparc-rtems-objcopy such this line
>>     below:
>>     "sparc-rtems-objcopy -O binary name_of_source_ exe
>>     name_of_binary.bin"
>>     that  is the "same" line I use on my ARM, excpet it
>>     arm-rtems-objcopy not sparc-rtems-objcopy.
>>         In  my Makefile I also use these commands:
>>         sparc-rtems-strip $@.exe
>>         sparc-rtems-objcopy --remove-section=.comment $@.exe
>>         but the final .exe file is always large, about 300KB from the
>>         original 3MB.
>>         Should I use other commands? Thanks
>>         Il 03/04/2012 18.04, Rhenzo Losso ha scritto:
>>>         Greetings,
>>>         Maybe you can use the sparc-rtems-objdump or
>>>         sparc-rtems-strip. I'm using RTEMS on arm processor (CSN637
>>>         port) and I use arm-rtems-objcopy to transform the arm.exe
>>>         into arm.bin. It reduce from 2MB to near 147kB.
>>>             Hi all,
>>>             I'm new of the list and I have a simple question. I
>>>             compiled a simple "Hello World" c code
>>>             with sparc-rtems-gcc, but the generated executable is
>>>             about 3MB, so much for my use...
>>>             I don't know why the executable file is so large... How
>>>             can I reduce its size?
>>>             Thank you
>>>                 Luca
>>>             _______________________________________________
>>>             rtems-users mailing list
>>>             rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>>             http://www.rtems.org/mailman/listinfo/rtems-users
>>>         Rhenzo Losso
>>>         Bacharel em Ciência da Computação - UNESP / São José do Rio
>>>         Preto
>>>         Instituto Tecnológico de Aeronáutica
>>>         Praça Marechal do Ar Eduardo Gomes, no. 50 - Sala 253 -
>>>         Projeto ITASAT
>>>         Vila das Acácias
>>>         12228-900 Sao Jose dos Campos, SP, Brazil
>>>         +55 012 3947-6903 <tel:%2B55%20012%203947-6903> (Sala do ITA)
>>     Rhenzo Losso
>>     Bacharel em Ciência da Computação - UNESP / São José do Rio Preto
>>     Praça Marechal do Ar Eduardo Gomes, no. 50 - Sala 253 - Projeto
>>     ITASAT
>>     Vila das Acácias
> Rhenzo Losso
> Praça Marechal do Ar Eduardo Gomes, no. 50 - Sala 253 - Projeto ITASAT
> Vila das Acácias
> +55 012 3947-6903 (Sala do ITA)
Joel Sherrill, Ph.D.             Director of Research&   Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20120403/555aca36/attachment-0001.html>
