Motorola Shared BSPs not Linking
Sebastian Huber
Mon Apr 23 09:57:04 UTC 2012
On 04/23/2012 11:27 AM, Sebastian Huber wrote:
> I think this is a bug in ld introduced with 2.22. We have this command line:
> powerpc-rtems4.11-ld -o hello.ralf ../../../../../mcp750/lib/bootloader.o
> --just-symbols=hello.exe -b binary rtems.gz -T
> ../../../../../mcp750/lib/ppcboot.lds -Map hello.map
> ../../../../../mcp750/lib/ppcboot.lds:97: undefined symbol `__rtems_start'
> referenced in expression
> This "__rtems_start" is defined in "hello.exe" (defined in "vectors_entry.S").
> If I change "__rtems_start" to "boot_card" it get also this error. If I
> change it to "memcpy" the error disappears. With older Binutils all versions
> work.
After using this shell script:
rm -f log.txt
for i in `nm -g hello.exe | awk '/ T / {print $3}'` ; do
sed s%__rtems_start%$i% < ../../../../../mcp750/lib/ppcboot.lds > ppcboot.lds.$i
if powerpc-rtems4.11-ld -o hello.ralf ../../../../../mcp750/lib/bootloader.o
--just-symbols=hello.exe -b binary rtems.gz -T ppcboot.lds.$i -Map hello.map ; then
echo good $i >> log.txt
else
echo bad $i >> log.txt
fi
done
it seems to be completely random which symbols are undefined and which are defined.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
