Supported ARM BSPs
Fered a_Fered at yahoo.com
Mon Apr 30 03:50:20 UTC 2012
The problem is which BSPs are actually available?!
I want to buy a board and I'm not sure which board has a BSP (whithout
modification or any additional attempt!).
And I intend to do 2 other works (customize a BSP for my own board and use a
simulator) but they are not in priority.
Thanks
Joel Sherrill wrote:
> I don't know what you are trying to do. Buy a board that has. BSP. Pick a
> BSP with simulator support. Pick one close to a custom board being built.
> When you count the variants, there are lots of BSPs.
> Gedare Bloom <gedare at rtems.org> wrote:
> >The boards you listed are available in the development branch of RTEMS
> >(git repository head, aka 4.11). So the easiest thing would be to use
> >4.11 if that is an option for you. I'm unsure about the bsps available
> >in 4.10 without going to look at the source. You can find them in
> >c/src/lib/libbsp/arm/ subdirectories. BSP variants are defined in the
> >make/custom/*.cfg files within a bsp's subdirectory.
> >-Gedare
> >On Sun, Apr 29, 2012 at 1:22 AM, Fered <a_Fered at yahoo.com> wrote:
> >> I want to prepare a board that RTEMS has a BSP for it. It seems that
> >> the
> >> website is not reliable!
> >> Please tell me if BSP of any Cortex based board is available and how
> >> can I use it.
> >> Thanks a lot.
> >> Fernando Nicodemos wrote:
> >>> Dear Fered,
> >>> There is also the csb637 bsp which is a variant of csb337.
> >>> Unfortunately i did not work with these bsps yet. I tried to find
> >>> them also and itsnames but i could not. Maybe they are variants of
> >>> other bsps but are not described well in wiki with proper names.
> >>> Regards
> >>> Em sábado, 28 de abril de 2012, Fered escreveu:
> >>> > Hi;
> >>> > In RTEMS website, I see following BSPs are impelemented:
> >>> >    - NXP LPC17XX (pin compatible to LPC24XX with ARM Cortex-M3
> >>> > core)
> >>> >    - Stellaris Microcontroller LM3S6965
> >>> >    - STMicroelectronics STM32 F4
> >>> > I work with RTEMS-4.10.2 and only following BSPs are in the
> >>> > source:
> >>> > csb336, csb337, edb7312, gba, gp32, nds, rtl22x, rtl22xx_t,
> >>> > smdk2410
> >>> > How can I add those 3 BSPs?
> >>> > Those 3 items, are names of micro controllers. We have BSP of
> >>> > any board that use those micro controllers?
> >>> > Thanks
> >>> Sent from Gmail Mobile
> >> _______________________________________________
> >> rtems-users mailing list
> >> rtems-users at rtems.org
> >> http://www.rtems.org/mailman/listinfo/rtems-users
