[GSoC] CSB337 and skyeye 1.2.2
Xi Yang
hiyangxi at gmail.com
Wed Aug 1 01:29:50 UTC 2012
Hi Hesham,
Do you must need CSB337 BSP?
Regards.
On 1 August 2012 05:47, Hesham Moustafa <heshamelmatary at gmail.com> wrote:
> Hi,
> I have tried to apply the patch here [1] to get CSB337 working on skyeye
> When i run the script at sim-scripts directory and cat log/hello that's i
> got
> $ ./csb337 ...../hello.exe
> running ...../hello.exe for maximum 60 seconds...
> and it hangs
> Then i run this command
> $cat log/hello
> and i got this output
> " 1 arch: arm
> 2 cpu info: armv4, arm920t, 41009200, ff00fff0, 2
> 3 mach info: name at91rm92, mach_init addr 0x8060420
> 4 SKYEYE: use arm920t mmu ops
> 5 uart_mod:1, desc_in:/dev/null, desc_out:/dev/stdout
> 6 exec file
> "/home/hesham/csb337/arm-rtems4.11/c/csb337/testsuites/samples/hello/hello.exe"'s
> format is elf32-little.
> 7 not load section .vector: addr = 0x00200000 size = 0x000005c0 .
> 8 load section .text: addr = 0x20104000 size = 0x00017eec.
> 9 load section .init: addr = 0x2011beec size = 0x00000020.
> 10 load section .fini: addr = 0x2011bf0c size = 0x0000001c.
> 11 load section .rodata: addr = 0x2011bf28 size = 0x00001984.
> 12 load section .eh_frame: addr = 0x2011d8ac size = 0x00000004.
> 13 load section .ctors: addr = 0x2011d8b0 size = 0x00000008.
> 14 load section .dtors: addr = 0x2011d8b8 size = 0x00000008.
> 15 load section .jcr: addr = 0x2011d8c0 size = 0x00000004.
> 16 load section .data: addr = 0x2011d8c4 size = 0x00000a64.
> 17 not load section .bss: addr = 0x2011e340 size = 0x00001a68 .
> 18 not load section .work: addr = 0x2011fda8 size = 0x00ee0258 .
> 19 not load section .comment: addr = 0x00000000 size = 0x00000048 .
> 20 not load section .debug_aranges: addr = 0x00000000 size = 0x00002970 .
> 21 not load section .debug_info: addr = 0x00000000 size = 0x0015bc6b .
> 22 not load section .debug_abbrev: addr = 0x00000000 size = 0x00025767 .
> 23 not load section .debug_line: addr = 0x00000000 size = 0x0003dd19 .
> 24 not load section .debug_frame: addr = 0x00000000 size = 0x00004ff0 .
> 25 not load section .debug_str: addr = 0x00000000 size = 0x0001085b .
> 26 not load section .debug_loc: addr = 0x00000000 size = 0x0001dc51 .
> 27 not load section .debug_ranges: addr = 0x00000000 size = 0x00002db0 .
> 28 not load section .ARM.attributes: addr = 0x00000000 size = 0x00000010 .
> 29 start addr is set to 0x20104000 by exec file.
> I need to get this BSP working on Skyeye as my project depends or its core
> i think i am close, that's why i am sending this e-mail hoping to get some
> help.
> Thanks,
> Hesham
> [1]http://www.rtems.org/pipermail/rtems-users/attachments/20070625/ddf6facd/attachment.obj
> rtems-users mailing list
> rtems-users at rtems.org
