[GSoC] CSB337 and skyeye 1.2.2
Wed Aug 1 14:27:08 UTC 2012
The requirement is to find a suitable ARM target that uses the CP15
MMU and can be tested under simulation. Alternatives or suggestions
that are known to work are also welcome.
-Gedare
On Tue, Jul 31, 2012 at 9:29 PM, Xi Yang <hiyangxi at gmail.com> wrote:
> Hi Hesham,
> Do you must need CSB337 BSP?
> Regards.
> On 1 August 2012 05:47, Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>> Hi,
>> I have tried to apply the patch here [1] to get CSB337 working on skyeye
>> When i run the script at sim-scripts directory and cat log/hello that's i
>> got
>> $ ./csb337 ...../hello.exe
>> running ...../hello.exe for maximum 60 seconds...
>> and it hangs
>> Then i run this command
>> $cat log/hello
>> and i got this output
>> "  1 arch: arm
>>   2 cpu info: armv4, arm920t, 41009200, ff00fff0, 2
>>   3 mach info: name at91rm92, mach_init addr 0x8060420
>>   4 SKYEYE: use arm920t mmu ops
>>   5 uart_mod:1, desc_in:/dev/null, desc_out:/dev/stdout
>>   6 exec file
>> "/home/hesham/csb337/arm-rtems4.11/c/csb337/testsuites/samples/hello/hello.exe"'s
>> format is elf32-little.
>>   7 not load section .vector: addr = 0x00200000  size = 0x000005c0 .
>>   8 load section .text: addr = 0x20104000  size = 0x00017eec.
>>   9 load section .init: addr = 0x2011beec  size = 0x00000020.
>>  10 load section .fini: addr = 0x2011bf0c  size = 0x0000001c.
>>  11 load section .rodata: addr = 0x2011bf28  size = 0x00001984.
>>  12 load section .eh_frame: addr = 0x2011d8ac  size = 0x00000004.
>>  13 load section .ctors: addr = 0x2011d8b0  size = 0x00000008.
>>  14 load section .dtors: addr = 0x2011d8b8  size = 0x00000008.
>>  15 load section .jcr: addr = 0x2011d8c0  size = 0x00000004.
>>  16 load section .data: addr = 0x2011d8c4  size = 0x00000a64.
>>  17 not load section .bss: addr = 0x2011e340  size = 0x00001a68 .
>>  18 not load section .work: addr = 0x2011fda8  size = 0x00ee0258 .
>>  19 not load section .comment: addr = 0x00000000  size = 0x00000048 .
>>  20 not load section .debug_aranges: addr = 0x00000000  size = 0x00002970 .
>>  21 not load section .debug_info: addr = 0x00000000  size = 0x0015bc6b .
>>  22 not load section .debug_abbrev: addr = 0x00000000  size = 0x00025767 .
>>  23 not load section .debug_line: addr = 0x00000000  size = 0x0003dd19 .
>>  24 not load section .debug_frame: addr = 0x00000000  size = 0x00004ff0 .
>>  25 not load section .debug_str: addr = 0x00000000  size = 0x0001085b .
>>  26 not load section .debug_loc: addr = 0x00000000  size = 0x0001dc51 .
>>  27 not load section .debug_ranges: addr = 0x00000000  size = 0x00002db0 .
>>  28 not load section .ARM.attributes: addr = 0x00000000  size = 0x00000010 .
>>  29 start addr is set to 0x20104000 by exec file.
>> I need to get this BSP working on Skyeye as my project depends or its core
>> i think i am close, that's why i am sending this e-mail hoping to get some
>> help.
>> Thanks,
>> Hesham
>> [1]http://www.rtems.org/pipermail/rtems-users/attachments/20070625/ddf6facd/attachment.obj
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
