Fours Days Until RTEMS Reaches Mars
Cláudio Silva claudiodcsilva at gmail.com
Thu Aug 2 14:48:39 UTC 2012
ESA qualified version is based on 4.8 but somewhat modified: only
sparc bsps (ERC32, Leon2, Leon3), no newlib, only a subset of RTEMS'
managers, no posix, no network, no drivers outside the bsp, no dead
code, ...
I think Astrium used(s?) 4.6.6 as a reference.
Cláudio
On Thu, Aug 2, 2012 at 3:25 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
> ESA has been slower updating. I think their latest validated version is based on 4.8.x.
> More recent NASA missions are using newer versions with MMS testing 4.10.
> The Electra radio circling Mars is old and was initially developed on 4.0.x as I recall from a
> published paper. I don't know what they ended up using on the one circling Mars.
> I think they updated to something newer on later models. But I don't know the details.
> We need a JPL person to comment... hint.. hint. :)
> --joel
> ________________________________________
> From: rtems-users-bounces at rtems.org [rtems-users-bounces at rtems.org] On Behalf Of Zandin Johan RUAG N [Johan.Zandin at ruag.com]
> Sent: Thursday, August 02, 2012 9:25 AM
> To: rtems-users at rtems.org
> Subject: RE: Fours Days Until RTEMS Reaches Mars
> Steven Grunza wrote:
>>My thought is that if someone was looking for the
>>most stable and reliable [version / hw / cpu] combination I
>>would try to match what is/has been sent on inter-planetary journeys.
> Good thought!
> As you can see on http://wiki.rtems.org/wiki/index.php/Herschel_%26_Planck
> Herschel and Planck use RTEMS 4.5.0 (with patches applied).
> Several ESA missions launched more recently, soon to be launched or still
> in development (e.g. Galileo, GAIA, Sentinel-2 and Solar Orbiter) use
> RTEMS 4.6.1, 4.6.2 or 4.6.6 (with patches applied and sometimes with
> unused code stripped away).
> Those versions are rather old by now. But they are usually thoroughly
> analysed and tested by ESA or its subcontractors. So most of their bugs
> should be found by now. Just make sure to apply the corresponding patches!
> Best regards
> Johan Zandin
> Johan Zandin                      Senior Software Engineer
> RUAG Space AB                     Phone: +46-31-735 41 47
> SE-405 15 Gothenburg, Sweden      Fax:   +46-31-735 40 00
> rtems-users mailing list
