Cheap big-endian board
Mathew Benson
mathew.benson at gmail.com
Fri Aug 3 16:35:40 UTC 2012
I have never used RTEMS, but would like to prototype some ideas for
using RTEMS on the job. I have no budget for a demo or prototype, so
I'm looking for cheap development boards. Can somebody recommend
cheap dev boards with the following criteria:
- RTEMS BSP available or easy to tailor or create one
- Big endian CPU (I'm porting code from an already existing big endian
project and don't want to byte swap)
- Inexpensive (preferably in the same price range as Beagleboard or Gumstix)
- Equivalent processing speed to a 400 MHz Pentium II or better
- Preferably no less than 128 MB of RAM
- Ethernet
- Programmable via USB, serial, or ethernet
I've been going through the platforms listed on the BSP wiki page but
haven't found a good one yet. I understand both Beagleboard and
Gumstix are bi-endian, but all the toolchains I find are setup for
little endian. Ideally, I would love to use the Gumstix. Can that be
setup big endian easily?
