ARINC-653 API
Mathew Benson mathew.benson at gmail.com
Fri Aug 3 20:48:47 UTC 2012
Do you have a website with info?  Is there anything I can help with?  ARINC 653 part 1, or part 2 also?  Part 1 is fairly simple.  Part 2 is a bit more work.
Sent from my iPhone
On Aug 3, 2012, at 3:22 PM, Cláudio Silva <claudiodcsilva at gmail.com> wrote:
> Hi Mathew,
> On Fri, Aug 3, 2012 at 6:28 PM, Mathew Benson <mathew.benson at gmail.com> wrote:
>> I'm new to both RTEMS and this mailing list.  I didn't see a mailing
>> list search utility so I skimmed posts going back several months and
>> saw a thread on RTEMS and ARINC-653.  I'm particularly interested in
>> using RTEMS for ARINC-653 applications.  I'm a professional not a
>> student, but I fully embrace the open source movement both in my
>> personal projects and professional projects when possible.  I
>> apologize if I'm resurrecting a dead thread or duplicating a thread,
>> but can I ask what the status of this effort is?
> Welcome to RTEMS. ;)
> The project regarding the ARINC 653 API is not yet started. We have an
> on-going google summer of code project to add RTEMS as a Partition
> Operating System on top of POK. The next logical step would be adding
> a ARINC653 api so we can have a ARINC653 compliant operating system.
>> I'm primarily just interested in running ARINC-653 partition code
>> without regard to actual space and time partitioning, for now.  I
>> already have a production environment.  I have a board level emulator
>> that runs the unmodified binaries but its many times slower than real
>> time.  I also have a Linux based simulated environment that satisfies
>> the ARINC 653 API and it is capable of running faster than real time,
>> but the endianness is flipped requiring an extra layer of code and
>> maintenance effort.
> Can i know which linux based simulator are you using?
>> Phase 1:
>> My first goal is to run my existing partition code, real time, without
>> modifications and without byte swapping.  In parallel, I'm using qemu
>> to do the same thing but I also want to find inexpensive big endian
>> boards (previous post) and run my code on those.  If this were a
>> personal project, I would use old PowerPC Macs, SPARCs, or whatever
>> consumer electronics device I could find.  However, since this is in
>> support of a professional project, I need to find something that I can
>> purchase and use without hacking, though I would still entertain using
>> discarded cell phones or network routers just for the coolness factor.
>> I had originally toyed with network routers, but can't find many with
>> the specs that I need.  Once I have my platform, OS, and BSP, I plan
>> on writing a simple ARINC 653 (part 1 only) layer on top of whichever
>> OS I use (preferably RTEMS) to satisfy the APEX API, writing system
>> partitions for platform specific functions (i.e. I/O and board health
>> monitoring), and running my code.  Internally, timing will be
>> completely out of whack, but the system partition providing I/O would
>> provide the appearance of at least minor frame timing coherence.  Some
>> failure scenarios wouldn't be emulated correctly, but I'm really only
>> interested in nominal operation anyway.
>> Phase 2 (currently not planned, but possible):
>> Join or start a project to provide a true space/time partitioned ARINC
>> 653 implementation of the target OS.
> You should take a look to the existing solutions which mix RTEMS and ARINC653:
> -> POK provides an ARINC653 interface and runs on PPC, SPARC and X86.
> POK is also directed into model based development using AADL for
> configuration.
> -> AIR was derived from RTEMS, runs on SPARC, and provides an ARINC653
> compliant API along with RTEMS. AIR also features an I/O partition
> with drivers for SpW, MIL-STD and Ethernet.
>> Phase 3 (probably wishful thinking):
>> Implement a DO178B certifiable ("-able", NOT "-ied") version of the target OS.
>> I know very little about RTEMS, but I'm more interested in using RTEMS
>> over Linux because it appears RTEMS was designed from the ground up
>> for real time embedded systems.
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
