Difference between task and tread
Joel Sherrill
Joel.Sherrill at OARcorp.com
Sat Aug 11 15:08:18 UTC 2012
In practical terms they are the same thing. The choice of ten depends whether you are viewing the Classic API which is based on RTEID and ORKID which called them talks. In POSIX the same computer science object is called a thread.
Internal to RTEMS we use the term thread because the Classic API used real and we wanted a distinction. Then we added POSIX threads and that standard used the same term we had internally.
joel
"m.shahverdi" <sspardis2 at gmail.com> wrote:
Hi all
what is difference between task and thread in RTEMS exactly?
thanks
URL: <http://lists.rtems.org/pipermail/users/attachments/20120811/f577066e/attachment.html>
