Semaphore Issue
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Aug 15 13:55:53 UTC 2012
On 08/14/2012 07:34 PM, Kirspel, Kevin wrote:
> BTW, is there any downside to enabling strict order mutex? This will
> fix our issue but I’m not sure what other ramifications it may have.
> We use a handful of semaphores (mostly for hardware protection) but I
> noticed that RTEMS creates a lot (mostly LBI*).
I would run all the tests after enabling it. :)
I think it might use a little more memory for the additional
bookkeeping. It also may result in your application getting an
error code if you unlock in the wrong order.
We need to discuss as a community if this should be turned on
by default. Honestly, I was surprised we had forgotten to switch
to this as default. :(
> Kevin Kirspel
> Senior Research Engineer
> Opti Medical
> 235 Hembree Park Drive
> Roswell GA 30076
> Tel: (770)-510-4444 ext. 81642
> Direct: (770)-688-1642
> Fax: (770)-510-4445
> *From:*Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> *Sent:* Tuesday, August 14, 2012 5:47 PM
> *To:* Kirspel, Kevin
> *Cc:* rtems-users at rtems.org
> *Subject:* Re: Semaphore Issue
> On 08/14/2012 04:15 PM, Kirspel, Kevin wrote:
> I have a situation with semaphores that I thought someone may have a
> quick explanation for. The scenario consists of 2 semaphore/mutexes
> and priority inheritance. The first semaphore is created by the
> application (S1) and is of type: RTEMS_BINARY_SEMAPHORE |
> RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY. The second (S2) is the
> allocator lock mutex that is used by malloc(). My scenario is as follows.
> Task 1 has priority 36. Task 2 has priority 34.
> 1.Task 1 obtains S1.
> 2.Task 1 obtains S2
> 3.Task 2 preempts Task 1.
> 4.Task 2 tries to obtain S2 but can’t get it. Task 1 priority is
> changed to 34.
> 5.Task 1 begins running again. Task 1 releases S2. Task 1 priority
> is not changed back to 36 and continues to run.
> 6.Task 1 continues operating for 3 more seconds.
> 7.Task 1 releases S1. Task 1 priority is now changed back to 36.
> 8.Task 2 now preempts Task 1 and begins operating again.
> What RTEMS version is this?
> This sounds like the priority inheritance release algorithm described
> here:
> http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/c_user_208.html#Semaphore-Manager-Priority-Inheritance
> Priority inherited is not lowered until ALL mutexes are released.
> There is an optional algorithm (don't recall if it is turned on by
> default) that
> is guarded by the __RTEMS_STRICT_ORDER_MUTEX__ conditional.
> configure with ENABLE_STRICT_ORDER_MUTEX=1 on the command line to
> try this algorithm which should properly step down as each mutex is
> released.
> Task 1 is the main user of Semaphore S1. During normal operation no
> other task will try to obtain it. It is there to protect against some
> custom shell commands that may access the same data. Semaphore S2 is
> widely used since it protects memory allocation. If
> obtaining/releasing S1 is removed from the scenario above then
> everything works OK.
> 1.Task 1 obtains S2
> 2.Task 2 preempts Task 1.
> 3.Task 2 tries to obtain S2 but can’t get it. Task 1 priority is
> changed to 34.
> 4.Task 1 begins running again. Task 1 releases S2. Task 1 priority
> 5.Task 2 now preempts Task 1 and begins operating again.
> 6.Task 2 enters wait condition.
> 7.Task 1 continues operating for 3 more seconds and then enters wait
> condition.
> I am going to try and duplicate this scenario using a small test
> program but I wanted to see if anyone had any ideas of what may be
> causing the issue. I have a mixed RTEMS source base between versions
> 4.10 and 4.11. I started with 4.10 and upgraded just enough to get
> USB support.
> Any chance you want to pitch in and help resolve some issues on the
> TCP/IP side?
> We are now up to the IPV4 loopback test and would LOVE to have help. :)
> Kevin Kirspel
> Opti Medical
> Roswell GA 30076
> Fax: (770)-510-4445
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20120815/771732c0/attachment.html>
