changes to the core Nios2 RTEMS IIC model
Hill, Jeff johill at lanl.gov
Wed Aug 15 14:41:38 UTC 2012
Hello Sebastian,
> some more comments regarding the thread stack usage of ISRs.
> On 14/08/12 03:05, Hill, Jeff wrote:
> > __attribute__ ((section (".text_hotspot")))
> > void __ISR_Handler ( void )
> The code that calls __ISR_Handler() will save the volatile context on
> the thread stack, right?
correct
> >    if ( _ISR_Nest_level == 0) {
> > #   if( CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE)
> >        stack_ptr = _old_stack_ptr;
> > #   endif
> >      if ( !_Thread_Dispatch_in_critical_section() ) {
> >        if ( _Thread_Is_dispatch_necessary () ) {
> >          _CPU_ISR_Enable ( isrCookie );
> What does the _CPU_ISR_Enable() here?  Will it really enable the
> interrupts?
The _CPU_ISR_Enable will of course _globally_ enable interrupts in the Nios2
status register.
> In case it enables interrupts then the code that calls
> __ISR_Handler() will save a volatile context on the thread stack (it is
> now the second).  In case the interrupt is pending a long time (some
> sort of error) or you have a bad sequence of interrupts, then this can
> stack several times and blow your thread stack.
With the IIC the interrupt's priority is defined by its bit position
in the ipending  and ienable register.
Note that this is the Nios2 with internal interrupt controller so a
particular interrupt will not occur unless it is _also_ enabled in the
Nios2 ienable register, and as I mentioned in my previous
mail the interrupts of equal or lower priority are previously disabled
by the following code that writes to the Nios2 ienable register. We will
not start a new interrupt context for the same or lower priority interrupt
with the IIC unless it is _also_ enabled in the ienable register; therefore
the interrupt contexts will nest only 32 deep.
  uint32_t vector = CPU_INTERRUPT_NUMBER_OF_VECTORS;
     * we should always take the first branch but conservative
     * code is a good idea for an ISR
     * __builtin_ctz produces undefined result if ipending is
     * zero
    uint32_t newEnbl = NIOS2_IENABLE_NO_INTERNAL_INTERRUPTS;
    if ( ipending ) {
      vector = __builtin_ctz ( ipending );
      if ( vector < CPU_INTERRUPT_NUMBER_OF_VECTORS ) {
        pHandler = _ISR_Vector_table[ vector ];
         * disable nios2 internal interrupts of equal or lower level
         * (we restore the interrupt level in the low level code
         * so that we dont explode the interrupt stack when there
         * is an unquenched interrupt source)
         * Bit 0 in the ipending register has highest priority
         * and bit 31 has lowest priority.
        newEnbl = ( 1u << vector ) - 1u;
    __builtin_wrctl ( NIOS2_CTLREG_INDEX_IENABLE, newEnbl );
> >          _Thread_Dispatch ();
> >          /* may have switched to another task and not return here immed.
> >          _CPU_ISR_Disable ( isrCookie ); /* Keep _pairs_  of
> Enable/Disable */
> >    _CPU_ISR_Enable( isrCookie );
Best regards,
Jeff
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
