RES: Rate Monotonic Scheduling
Wendell Pereira da Silva wendell.silva at compsisnet.com.br
Tue Aug 21 14:35:30 UTC 2012
Fered,
AFAIK, a RM task (in RTEMS) just own one or more period objects. You should be able to provide your own priority scheme. So, careful should be taken to assign priorities, task attributes as well as task modes.
--Wendell.
-----Mensagem original-----
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de Fered
Enviada em: terça-feira, 21 de agosto de 2012 02:42
Para: rtems-users at rtems.org
Assunto: Rate Monotonic Scheduling
Hi;
As every one know, in RM scheduling, more frequent tasks(with shorter period) have higher priority. When we use rate monotonic facilities in RTEMS, does the OS set tasks priority according to it's period length or we should set the priorities ourself?
Thank you.
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
