ANN: microblaze-rtems4.11 toolchain
Ralf Corsepius ralf.corsepius at rtems.org
Fri Aug 24 13:06:10 UTC 2012
On 08/24/2012 02:46 PM, Joel Sherrill wrote:
> It is Chris' tool. If you are on a host you have worked actively not to support or you want to build the tools easily on a non-RPM host matching your versions, diffs, and commands, then it is the only option.
OK, this tool some times, somewhat works, but in general it often
doesn't work. On a wider scope, I think its design lacks from its basis.
(Was it ever tested on Ubuntu - Does it take Ubuntu's weird notions on
multilibs in account?)
> You only work to support a fragment of the community.
Correct, I have been actively sharing my works on platforms/OSes which I
am technically able to support and I consider support-worthy.
> Don't be a hindrance to those who didn't choose from your list of preferred host OSes.
Listen, Dr. Sherrill, while you are in a position to permantently
undermine my works (The works which had kept RTEMS alive throughout the
last decade) you are not in a position to push me around!
Ralf
