ANN: microblaze-rtems4.11 toolchain
Michal Simek monstr at monstr.eu
Fri Aug 24 15:06:57 UTC 2012
On 08/24/2012 02:46 PM, Joel Sherrill wrote:
> It is Chris' tool. If you are on a host you have worked actively not to support or you want to build the tools easily on a non-RPM host matching your versions, diffs, and commands, then it is the only option.
> You only work to support a fragment of the community. Don't be a hindrance to those who didn't choose from your list of preferred host OSes.
I have no problem to setup virtual machine with tested OS and just use it.
Thanks,
Michal
Michal Simek, Ing. (M.Eng)
w: www.monstr.eu p: +42-0-721842854
Maintainer of Linux kernel 2.6 Microblaze Linux - http://www.monstr.eu/fdt/
Microblaze U-BOOT custodian
