ANN: microblaze-rtems4.11 toolchain
Ralf Corsepius ralf.corsepius at rtems.org
Fri Aug 24 15:15:21 UTC 2012
On 08/24/2012 05:06 PM, Michal Simek wrote:
> On 08/24/2012 02:46 PM, Joel Sherrill wrote:
>> It is Chris' tool. If you are on a host you have worked actively not
>> to support or you want to build the tools easily on a non-RPM host
>> matching your versions, diffs, and commands, then it is the only option.
>> You only work to support a fragment of the community. Don't be a
>> hindrance to those who didn't choose from your list of preferred host
>> OSes.
> I have no problem to setup virtual machine with tested OS and just use
> it.
That's another option.
FWIW: Though I personally don't like Ubuntu and consider rpm-based
distros to be superior to deb based distros, the reason for me not
packaging for Ubuntu/Debian primarily are of technical nature and in
second place are a resources problem (lack of time, lack of sufficiently
performant machines). I once tried, but failed and gave up ;)
Ralf
