ANN: microblaze-rtems4.11 toolchain
Michal Simek monstr at monstr.eu
Fri Aug 24 15:31:56 UTC 2012
On 08/24/2012 05:10 PM, Ralf Corsepius wrote:
> On 08/24/2012 05:04 PM, Michal Simek wrote:
>> On 08/24/2012 02:20 PM, Ralf Corsepius wrote:
>>> On 08/24/2012 02:07 PM, Joel Sherrill wrote:
>>>  > What was the configure command spec builder used?
>>> Is this Chris's tool?
>>> I do not recommend using it.
>> ok. then. What do you recommend me to use?
>> I want to compile toolchain myself. Mainline version at first.
> Option #1 is to write a build script based on
> rtems-4.11-microblaze-rtems4.11-gcc.spec
> (This is rpm syntax, so this would not be a trivial task for somebody not being familar with it).
not going to do.
> Option #2 would be to dig out Eric Normum's build-script, he sent to this list not too long ago (IIRC, he sent it as part of a microblaze related mail several weeks ago- Should be findable in this or the rtems-devel mailing-list's archive)
Have found it and will try. It is not for microblaze but it looks like as a good start.
Thanks,
Michal
Michal Simek, Ing. (M.Eng)
w: www.monstr.eu p: +42-0-721842854
Maintainer of Linux kernel 2.6 Microblaze Linux - http://www.monstr.eu/fdt/
Microblaze U-BOOT custodian
