ANN: microblaze-rtems4.11 toolchain
Ralf Corsepius ralf.corsepius at rtems.org
Fri Aug 24 15:32:32 UTC 2012
Sorry, now, I am really running out of time - I'll try to answer some
time later this weekend.
On 08/24/2012 05:25 PM, Michal Simek wrote:
> On 08/24/2012 05:15 PM, Ralf Corsepius wrote:
>> On 08/24/2012 05:06 PM, Michal Simek wrote:
>>> On 08/24/2012 02:46 PM, Joel Sherrill wrote:
>>>> It is Chris' tool. If you are on a host you have worked actively not
>>>> to support or you want to build the tools easily on a non-RPM host
>>>> matching your versions, diffs, and commands, then it is the only
>>>> option.
>>>> You only work to support a fragment of the community. Don't be a
>>>> hindrance to those who didn't choose from your list of preferred
>>>> host OSes.
>>> I have no problem to setup virtual machine with tested OS and just
>>> use it.
>> That's another option.
>> FWIW: Though I personally don't like Ubuntu and consider rpm-based
>> distros to be superior to deb based distros,
> the reason for me not packaging for Ubuntu/Debian primarily are of
> technical nature and in second place are a resources problem
> (lack of time, lack of sufficiently performant machines). I once tried,
> but failed and gave up ;)
> Please correct me if I am wrong. You are pushing patches to
> binutils/gcc/gdb/newlib, etc.
> I just want to download several git repositories and compile them.
> Don't want to use any prepared packages because it will limit me to use our
> toolchain patches.
> I would expect that you will point me to one wiki page where it is written.
> Recommended OS for Linux is gentoo, centos, redhat, whatever.
> Run this script to check that all required tools are installed.
> Run this and this and it will just work.
> Thanks,
> Michal
