RTEMS 4.9.5 vs 4.10.2 Network Stack
SAeeD salpha.2004 at gmail.com
Sun Aug 26 09:25:54 UTC 2012
Dear all,
I'm currently running network-demos on Mini2440 BSP.
What makes me wonder is that various network-demos samples (like telnetd,
http, netdemo) works on RTEMS 4.9.5 but not on RTEMS 4.10.2.
The point is that both versions have the same network device driver. (As
their c/src/lib/libbsp/arm/mini2440/network/network.c files are the same.)
Also, I was able to send UDP packets in both versions so I think the
problem is not related to device drivers. One more evidence: The demos for
4.10.2 doesn't work on QEMU for Mini2440 too. I also checked rtems_gluc.c
for both versions to make sure that definition of
rtems_bsdnet_initialize_network() wasn't changed.
Does anyone have any hint, suggestion, advice, etc.? I do really appreciate
any comment.
Thanks
SAeeD
URL: <http://lists.rtems.org/pipermail/users/attachments/20120826/f5f824de/attachment.html>
