How to debug pc386 compiled program with gdb?
    Chris Johns
    chrisj at rtems.org
    Thu Aug 30 22:20:47 UTC 2012
SAeeD wrote:
>     I debug i386 programs using a basic serial port which is means most
>     recent motherboards do not work because serial ports are not common
>     and USB serial ports are no help. If you do have a serial port the
>     set up I use is:
> Can you talk more about this way of debugging Chris? As I understood,
> you run the RTEMS application on a PC with serial port (say A). Then you
> connect the other side of serial port cable to another computer (say B)
> which runs the code that you sent the links in your email? And are you
> able to place breakpoint or to step code execution with serial port? Can
> you explain more about the mechanism and setup?
I have a server running DHCP and TFTP servers. A build script copies the
RTEMS executable image to the server where the TFTP server can see it.
The PC I have uses a Grub PXE network boot loader configured to load a
grub configuration file over the network using TFTP. The config file
contains:
  #!gpxe
  kernel tftp://10.10.10.10/sw/ul/rtld --gdb --console=com1,115200
  --ide=0,1
  boot rtld
Grub will load RTEMS into the PC over the network and start it running
and the code will break here:
  http://git.rtems.org/chrisj/rtl.git/tree/pc386-gdb.c#n36
In the code referenced above I connect to COM2 (the console is COM1).
The --gdb option on the kernel boot arguments is handled here:
  http://git.rtems.org/chrisj/rtl.git/tree/main.c#n381
The grub setup can be a little complex and there are notes in the README
in the PC bsp. They may be a bit out of date but the ideas are there and
a base to start playing. I tend to hang onto old motherboards with
serial ports, floppy disk connectors and PCI slots I can install a basic
networking card to do this type of development.
The host I run gdb on has the COM2 serial port from the target PC
connected to a USB to serial converted. This is the gdb initialization file:
  http://git.rtems.org/chrisj/rtl.git/tree/pc586-gdbinit-script
The checked in version is for qemu. If you uncomment lines 5 and 6 and
comment line 7 the serial port will be used. Just copy this file to
.gdbinit next to the RTEMS executable you get gdb to load.
