Interrupt in RTEMS
Gedare Bloom
gedare at rtems.org
Wed Aug 1 20:24:20 UTC 2012
I guess you might look at how a particular CPU handles interrupts. The
CPU Supplemental manual provides some details:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/cpu_supplement/cpu_supplement.html
RTEMS supports up to 256 interrupt priority levels, but CPUs might not
support so many.
Number of interrupts depends on how many interrupt sources the CPU supports.
-Gedare
On Wed, Aug 1, 2012 at 3:12 PM, m.shahverdi <sspardis2 at gmail.com> wrote:
> Yes,I know it.I want to know about interrupt kinds,number of each of them
> and interrupt priorities.
> On Wed, Aug 1, 2012 at 11:35 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> I don't really know where to start. Is there something in particular
>> you need to know? Interrupt sources and interrupt handling are
>> hardware-specific (although often can be shared across processor
>> families). The most common interrupt you will find in RTEMS is the one
>> that drives the clock driver.
>> On Wed, Aug 1, 2012 at 2:51 PM, m.shahverdi <sspardis2 at gmail.com> wrote:
>> > Hi all,
>> > RTEMS c_user document explains interrupt management briefly but I want
>> > to
>> > know more about interrupt properties such as kinds of interrupt in RTEMS
>> > and
>> > so.
>> > thanks
>> > _______________________________________________
>> > rtems-users mailing list
>> > rtems-users at rtems.org
>> > http://www.rtems.org/mailman/listinfo/rtems-users
> به "هوالحی" زنده می کند؛
> آنسان که می میراند به "هوالممیت"..
> ما را به "هوالشهید" است که مدام می میراند و زنده می کند..
