Cheap big-endian board
Mathew Benson
mathew.benson at gmail.com
Fri Aug 3 20:52:34 UTC 2012
We already have my code running on the PC. We have to correct endianness though. That's why I'm looking for a big endian board.
Sent from my iPhone
On Aug 3, 2012, at 3:45 PM, Andrei Chichak <groups at chichak.ca> wrote:
> On 2012-August-03, at 2:26 PM, Mathew Benson wrote:
>> Yes, I preferred PowerPC but didn't find anything even close to my budget so I considered all PowerPC out.
> There is always the Freescale TRK-MPC5642M which uses an MPC5634M powerpc chip for embedded automotive applications … scratch that, you needed cheap and fast. This board is $99 but only runs at 80MHz., on the other hand it does have a built in debugger and an eTPU for timing critical pulse generation stuff. You would also have to adapt an existing BSP.
> How about an off the shelf PC and use the Pc386 BSP? Cheap - yep, fast as you need - should do, lots of I/O - err not really, well documented - depends.
> A
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20120803/dc33cbf1/attachment-0001.html>
