Simulator for MPC5200
Binkowski, Cassio cassioiks at gmail.com
Tue Aug 7 19:30:53 UTC 2012
Thank you Steven!
I was able to get it from your tips.
Now, another doubt. I know the following won't do it for PowerPC:
~/qemu/install/bin/qemu-system-i386 -M pc -m 128     -boot a -fda
/home/rtems/qemu/pc386_fda -hda fat:/home/rtems/qemu/hd/ -serial stdio
--no-reboot
Besides using *qemu-system-ppc* and *-M prep*, what else do I have to
change to make it work?
I know that I'll have to change the -FDA term, but I don't what to change
it for.
Does anybody know this?
Thanks
On Tue, Aug 7, 2012 at 9:49 AM, Steven Grunza <sgrunza at ctdi.com> wrote:
> Looks like you tried to configure within the qemu source directory.  I
> usually build in a separate directory.****
> mkdir b-qemu****
> cd b-qemu****
> ../qemu.git/configure --target-list="ppc-softmmu" --prefix=/usr/local/bin*
> Install prefix    /usr/local/bin****
> BIOS directory    /usr/local/bin/share/qemu****
> binary directory  /usr/local/bin/bin****
> library directory /usr/local/bin/lib****
> include directory /usr/local/bin/include****
> config directory  /usr/local/bin/etc****
> Manual directory  /usr/local/bin/share/man****
> ELF interp prefix /usr/gnemul/qemu-%M****
> Source path       /home/grunzasr/qemu.git****
> C compiler        gcc****
> Host C compiler   gcc****
> CFLAGS            -O2 -D_FORTIFY_SOURCE=2 -g ****
> QEMU_CFLAGS       -fPIE -DPIE -m64 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64
> -D_LARGEFILE_SOURCE -Wstrict-prototypes -Wredundant-decls -Wall -Wundef **
> -Wwrite-strings -Wmissing-prototypes -fno-strict-aliasing  -Werror
> -fstack-protector-all -Wendif-labels -Wmissing-include-dirs
> -Wnested-externs ****
> -Wformat-security -Wformat-y2k -Winit-self -Wold-style-definition
> -I/usr/include/libpng12  ****
> LDFLAGS           -Wl,--warn-common -Wl,-z,relro -Wl,-z,now -pie -m64 -g *
> make              make****
> install           install****
> python            python****
> smbd              /usr/sbin/smbd****
> host CPU          x86_64****
> host big endian   no****
> target list       ppc-softmmu****
> tcg debug enabled no****
> Mon debug enabled no****
> gprof enabled     no****
> sparse enabled    no****
> strip binaries    yes****
> profiler          no****
> static build      no****
> -Werror enabled   yes****
> SDL support       yes****
> curses support    yes****
> curl support      no****
> mingw32 support   no****
> Audio drivers     oss****
> Extra audio cards ac97 es1370 sb16 hda****
> Block whitelist   ****
> Mixer emulation   no****
> VirtFS support    no****
> VNC support       yes****
> VNC TLS support   no****
> VNC SASL support  no****
> VNC JPEG support  yes****
> VNC PNG support   yes****
> xen support       no****
> brlapi support    no****
> bluez  support    no****
> Documentation     yes****
> NPTL support      yes****
> GUEST_BASE        yes****
> PIE               yes****
> vde support       no****
> Linux AIO support no****
> ATTR/XATTR support yes****
> Install blobs     yes****
> KVM support       yes****
> TCG interpreter   no****
> fdt support       no****
> preadv support    no****
> fdatasync         yes****
> madvise           yes****
> posix_madvise     yes****
> uuid support      no****
> libcap-ng support no****
> vhost-net support yes****
> Trace backend     nop****
> Trace output file trace-<pid>****
> spice support     no****
> rbd support       no****
> xfsctl support    no****
> nss used          no****
> usb net redir     no****
> OpenGL support    yes****
> libiscsi support  no****
> build guest agent yes****
> coroutine backend ucontext****
> grunzasr at stm32dbg% ls -FC****
> config-host.ld   config.log  libdis/       libhw32/  libuser/
> Makefile@  ppc-softmmu/     qdict-test-data.txt@  roms/****
> config-host.mak  libcacard/  libdis-user/  libhw64/  linux-headers/
> pc-bios/   qapi-generated/  QMP/                  tests/****
> grunzasr at stm32dbg%****
> I don’t know if the code will build but the “make” is currently running…**
> *From:* rtems-users-bounces at rtems.org [mailto:
> rtems-users-bounces at rtems.org] *On Behalf Of *Binkowski, Cassio
> *Sent:* Tuesday, August 07, 2012 6:54 AM
> *To:* Joel Sherrill
> *Cc:* rtems-users at rtems.org
> *Subject:* Re: Simulator for MPC5200****
> Ok. Downloaded the tools.****
> I'm trying to build Qemu for PowerPC now. I run the following line, as I
> found in the Notes file inside QEMU directory:****
> ./configure --target-list="ppc-softmmu" --prefix=/home/rtems/qemu/install
> >c.log 2>&1 ; echo $?****
> ... and get this:****
> head: cannot open `/root/Desktop/rtems\'' for reading: No such file or
> directory****
> head: cannot open `Home/qemu/qemu/VERSION' for reading: No such file or
> directory****
> ln: creating symbolic link `Home/qemu/qemu/Makefile.dis': No such file or
> directory****
> directory****
> ln: creating symbolic link `Home/qemu/qemu/linux-headers/asm-x86': No such
> file or directory****
> ln: creating symbolic link `Home/qemu/qemu/Makefile.target': No such file
> or directory****
> ln: creating symbolic link `Home/qemu/qemu/Makefile.hw': No such file or
> directory****
> directory****
> ./configure: line 3876: [: too many arguments****
> ln: creating symbolic link `Home/qemu/qemu/Makefile.user': No such file or
> directory****
> Has anyone had this before?****
> Best regards****
URL: <http://lists.rtems.org/pipermail/users/attachments/20120807/b488a96d/attachment-0001.html>
