Simulator for MPC5200
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Aug 8 13:52:58 UTC 2012
On 08/08/2012 08:19 AM, Gedare Bloom wrote:
> On Tue, Aug 7, 2012 at 8:09 PM, Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> On Tue, Aug 7, 2012 at 6:20 PM, Binkowski, Cassio
> <cassioiks at gmail.com <mailto:cassioiks at gmail.com>> wrote:
> On Tue, Aug 7, 2012 at 4:33 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>>
> wrote:
> On 08/07/2012 02:30 PM, Binkowski, Cassio wrote:
>> Thank you Steven!
>> I was able to get it from your tips.
>> Now, another doubt. I know the following won't do it for
>> PowerPC:
>> ~/qemu/install/bin/qemu-system-i386 -M pc -m 128
>> -boot a -fda /home/rtems/qemu/pc386_fda -hda
>> fat:/home/rtems/qemu/hd/ -serial stdio --no-reboot
>> Besides using *qemu-system-ppc* and *-M prep*, what else
>> do I have to change to make it work?
>> I know that I'll have to change the -FDA term, but I
>> don't what to change it for.
>> Does anybody know this?
> Check out rtems-testing from git. There is a directory in
> there called
> sim-scripts which has wrappers for almost all of the
> simulators
> we know you can run RTEMS on. You are looking for "qemuppc" :)
> Got it.
> It generates and error on line 227:
> 227. type ${runBSP}
> 228. check_status $? "Path appears to be broken (cannot find
> ${runBSP})"
> runBSP is declared in line 168:
> 168. runBSP=qemu-system-ppc
> Am I missing something?
> P.S: The file "qemu-system-ppc" is in the same directory level
> as the script and I'm passing the following parameters
> "./qemuppc -i test.exe"
> Put "." in your PATH or install qemu-system-ppc to a location in
> your PATH. The latter is a better option.
> I should add that putting "." in your PATH is a security risk. It is
> much better to install the binary to the appropriate location (which
> most likely is /usr/local/bin and already in your PATH).
The simulator needs to be in your PATH.
It is not invoked that way. You invoke all of the scripts in sim-scripts
the same way.
BSP [options] EXE
For some the .exe is OK to run because the target simulator directly
runs ELF. For others,
you need to use the .ralf (RTEMS Application Loadable File) which is in
the random format
needed for the target BSP.
Usually you want something like this:
qemuppc -i FILE.exe
The -i says run it interactively. Otherwise, it just runs and captures
output in a log file
for later examination. These scripts are used for batch testing and
coverage testing.
> -Gedare
> Regards
>> Thanks
>> On Tue, Aug 7, 2012 at 9:49 AM, Steven Grunza
>> <sgrunza at ctdi.com <mailto:sgrunza at ctdi.com>> wrote:
>> Looks like you tried to configure within the qemu
>> source directory. I usually build in a separate
>> directory.
>> mkdir b-qemu
>> cd b-qemu
>> ../qemu.git/configure --target-list="ppc-softmmu"
>> --prefix=/usr/local/bin
>> Install prefix /usr/local/bin
>> BIOS directory /usr/local/bin/share/qemu
>> binary directory /usr/local/bin/bin
>> library directory /usr/local/bin/lib
>> include directory /usr/local/bin/include
>> config directory /usr/local/bin/etc
>> Manual directory /usr/local/bin/share/man
>> ELF interp prefix /usr/gnemul/qemu-%M
>> Source path /home/grunzasr/qemu.git
>> C compiler gcc
>> Host C compiler gcc
>> CFLAGS -O2 -D_FORTIFY_SOURCE=2 -g
>> QEMU_CFLAGS -fPIE -DPIE -m64 -D_GNU_SOURCE
>> -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE
>> -Wstrict-prototypes -Wredundant-decls -Wall -Wundef
>> -Wwrite-strings -Wmissing-prototypes
>> -fno-strict-aliasing -Werror -fstack-protector-all
>> -Wendif-labels -Wmissing-include-dirs -Wnested-externs
>> -Wformat-security -Wformat-y2k -Winit-self
>> -Wold-style-definition -I/usr/include/libpng12
>> LDFLAGS -Wl,--warn-common -Wl,-z,relro
>> -Wl,-z,now -pie -m64 -g
>> make make
>> install install
>> python python
>> smbd /usr/sbin/smbd
>> host CPU x86_64
>> host big endian no
>> target list ppc-softmmu
>> tcg debug enabled no
>> Mon debug enabled no
>> gprof enabled no
>> sparse enabled no
>> strip binaries yes
>> profiler no
>> static build no
>> -Werror enabled yes
>> SDL support yes
>> curses support yes
>> curl support no
>> mingw32 support no
>> Audio drivers oss
>> Extra audio cards ac97 es1370 sb16 hda
>> Block whitelist
>> Mixer emulation no
>> VirtFS support no
>> VNC support yes
>> VNC TLS support no
>> VNC SASL support no
>> VNC JPEG support yes
>> VNC PNG support yes
>> xen support no
>> brlapi support no
>> bluez support no
>> Documentation yes
>> NPTL support yes
>> GUEST_BASE yes
>> PIE yes
>> vde support no
>> Linux AIO support no
>> ATTR/XATTR support yes
>> Install blobs yes
>> KVM support yes
>> TCG interpreter no
>> fdt support no
>> preadv support no
>> fdatasync yes
>> madvise yes
>> posix_madvise yes
>> uuid support no
>> libcap-ng support no
>> vhost-net support yes
>> Trace backend nop
>> Trace output file trace-<pid>
>> spice support no
>> rbd support no
>> xfsctl support no
>> nss used no
>> usb net redir no
>> OpenGL support yes
>> libiscsi support no
>> build guest agent yes
>> coroutine backend ucontext
>> grunzasr at stm32dbg% ls -FC
>> config-host.ld config.log libdis/ libhw32/
>> libuser/ Makefile@ ppc-softmmu/
>> qdict-test-data.txt@ roms/
>> config-host.mak libcacard/ libdis-user/ libhw64/
>> linux-headers/ pc-bios/ qapi-generated/
>> QMP/ tests/
>> I don’t know if the code will build but the “make” is
>> currently running…
>> *From:*rtems-users-bounces at rtems.org
>> <mailto:rtems-users-bounces at rtems.org>
>> [mailto:rtems-users-bounces at rtems.org
>> <mailto:rtems-users-bounces at rtems.org>] *On Behalf Of
>> *Binkowski, Cassio
>> *Sent:* Tuesday, August 07, 2012 6:54 AM
>> *To:* Joel Sherrill
>> *Cc:* rtems-users at rtems.org
>> <mailto:rtems-users at rtems.org>
>> *Subject:* Re: Simulator for MPC5200
>> Ok. Downloaded the tools.
>> I'm trying to build Qemu for PowerPC now. I run the
>> following line, as I found in the Notes file inside
>> QEMU directory:
>> ./configure --target-list="ppc-softmmu"
>> --prefix=/home/rtems/qemu/install >c.log 2>&1 ; echo $?
>> ... and get this:
>> head: cannot open `/root/Desktop/rtems\'' for
>> reading: No such file or directory
>> head: cannot open `Home/qemu/qemu/VERSION' for
>> ln: creating symbolic link
>> `Home/qemu/qemu/Makefile.dis': No such file or directory
>> `Home/qemu/qemu/linux-headers/asm-x86': No such file
>> or directory
>> `Home/qemu/qemu/Makefile.target': No such file or
>> directory
>> `Home/qemu/qemu/Makefile.hw': No such file or directory
>> ./configure: line 3876: [: too many arguments
>> `Home/qemu/qemu/Makefile.user': No such file or directory
>> Has anyone had this before?
>> Best regards
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available(256) 722-9985 <tel:%28256%29%20722-9985>
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120808/f3cd8cab/attachment-0001.html>
