changes to the core Nios2 RTEMS IIC model
Sebastian Huber
Wed Aug 15 09:24:39 UTC 2012
Hello Jeff,
some more comments regarding the thread stack usage of ISRs.
On 14/08/12 03:05, Hill, Jeff wrote:
> __attribute__ ((section (".text_hotspot")))
> void __ISR_Handler ( void )
The code that calls __ISR_Handler() will save the volatile context on
the thread stack, right?
> if ( _ISR_Nest_level == 0) {
> # if( CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE)
> stack_ptr = _old_stack_ptr;
> # endif
> if ( !_Thread_Dispatch_in_critical_section() ) {
> if ( _Thread_Is_dispatch_necessary () ) {
> _CPU_ISR_Enable ( isrCookie );
What does the _CPU_ISR_Enable() here? Will it really enable the
interrupts? In case it enables interrupts then the code that calls
__ISR_Handler() will save a volatile context on the thread stack (it is
now the second). In case the interrupt is pending a long time (some
sort of error) or you have a bad sequence of interrupts, then this can
stack several times and blow your thread stack.
> _Thread_Dispatch ();
> /* may have switched to another task and not return here immed. */
> _CPU_ISR_Disable ( isrCookie ); /* Keep _pairs_ of Enable/Disable */
> _CPU_ISR_Enable( isrCookie );
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
