ANN: microblaze-rtems4.11 toolchain
Fri Aug 24 12:46:32 UTC 2012
It is Chris' tool. If you are on a host you have worked actively not to support or you want to build the tools easily on a non-RPM host matching your versions, diffs, and commands, then it is the only option.
You only work to support a fragment of the community. Don't be a hindrance to those who didn't choose from your list of preferred host OSes.
--joel
Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
>On 08/24/2012 02:07 PM, Joel Sherrill wrote:
> > What was the configure command spec builder used?
>Is this Chris's tool?
>I do not recommend using it.
> > Is flex in your PATH?
> From his mail:
> >> On my system is flex installed in version
> >> [specbuilder]$ flex --version
> >> flex 2.5.35
>Ralf
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-users
