how I can run test suites???
Christian Mauderer
Christian.Mauderer at embedded-brains.de
Tue Aug 28 06:29:14 UTC 2012
Hello,
the testsuite will be built together with the bsp if you call the
configure script with the additional --enable-tests option. If you just
want the samples (or another part of the tests), you can also use a
--enable-tests=samples.
Kind regards,
Christian Mauderer
Am 26.08.2012 12:21, schrieb m.shahverdi:
> Hi,
> How to build these tests for a specific target?
> thanks
> On Sun, Aug 26, 2012 at 1:06 PM, Pierre Ficheux
> <pierre.ficheux at openwide.fr <mailto:pierre.ficheux at openwide.fr>> wrote:
> I don't understand the question. What target (hardware) will you use?
> You just have to load the .exe to the board and run it.
> regards
> ----- Mail original -----
> > De: "mahmood hasanloo" <mahmood20810 at yahoo.com
> <mailto:mahmood20810 at yahoo.com>>
> > À: rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> > Envoyé: Samedi 25 Août 2012 14:53:21
> > Objet: how I can run test suites???
> > Dear All,
> > as I know there is a testsuite in /rtems/testsuites subdirectory
> > which we can test and evaluate behaviors of RTEMS. Also I know there
> > is a tmtests directory which contain 28 test program to evaluate
> > timing behavior of the OS. By the way how I can use them???
> > thanks in advance
> > Sincerely yours
> > Mahmood Hasanlou
> > rtems-users mailing list
> > http://www.rtems.org/mailman/listinfo/rtems-users
> به "هوالحی" زنده می کند؛
> آنسان که می میراند به "هوالممیت"..
> ما را به "هوالشهید" است که مدام می میراند و زنده می کند..
embedded brains GmbH
Christian Mauderer Obere Lagerstr. 30
D-82178 Puchheim Germany
email: Christian.Mauderer at embedded-brains.de
Phone: +49-89-18908079-0
Fax: +49-89-18908079-9
