How to debug pc386 compiled program with gdb?
Wed Aug 29 21:50:51 UTC 2012
Xiaochen Pan wrote:
> How to use i386-rtems4.11-gdb to debug pc386 compiled exe programs?
I debug i386 programs using a basic serial port which is means most
recent motherboards do not work because serial ports are not common and
USB serial ports are no help. If you do have a serial port the set up I
use is:
  http://git.rtems.org/chrisj/rtl.git/tree/pc386-gdb.c
  http://git.rtems.org/chrisj/rtl.git/tree/main.c#n378
Note, I add '--gdb' to the boot command line grub uses.
> Are all pc386 compiled files supposed to run with qemu emulator? Could they run without qemu? If it have to be with qemu, what instructions I should follow?
As already posted add the -s option to qemu. You can also tell qemu to
hold the i386 in reset allowing you to connect gdb, set a break point,
then run. This helps debug early boot type issues.
