RTEMS 4.9.5 vs 4.10.2 Network Stack
Pierre Ficheux pierre.ficheux at openwide.fr
Fri Aug 31 13:44:02 UTC 2012
Le 31/08/2012 12:52, SAeeD a écrit :
> As an extension to Bacon's email, I must mention that the following
> change is also necessary for the network part of RTEMS to run properly
> on Mini2440. In the file
> c/src/lib/libbsp/arm/mini2440/network/network.c, the following
> modification must happen:
> rtems_irq_connect_data dm9000_isr_data = {
>      BSP_EINT4_7,
>      (rtems_irq_hdl)dm9000_isr,
> NULL,
>      dm9000_isr_on,
>      dm9000_isr_off,
>      dm9000_isr_is_on
> };  /* unused for ARM */
Hmm, I got the following error when using telnetd.exe :
============== Start Telnetd ==============
Starting rtemsShell via telnetd -- default account is rtems w/no
password
Device: /dev/pty0../dev/pty7 (8)pseudo-terminals registered.
telnetd started with stacksize = 81920 and priority = 100
============== Deleting Init Task ==============
INSN_LDR
data_abort at address 0x3003D17C, instruction: 0xE596A018,   spsr =
0x60000013
active thread thread 0x0A010002
Previous sp=0x300AFE94 lr=0x3008BCA8 and actual cpsr=60000097
  0x3008BCA8 0x00000014 0x3017D80E 0x300AFECC 0x30098F6C 0x3008C174
  0x30098044 0x300AFED8 0x3017D01C 0x00000200 0x30098F6C 0x300AFEDC
  0x3008C220 0x30020C88 0x00000000 0x00000000 0x0000000A 0x043B5FC0
  0x3008C220 0x3008C16C 0x300AFF24 0x00040004 0x300AFECC 0x3008C16C
  0x300AFED4 0x00000000 0x3F14050A 0x30088CE0 0x3008BDF4 0x3008C230
  0x30088CE0 0x300AFECC 0x3008C16C 0x300AFED4 0x0000000C 0x30014370
  0x00040000 0x300142F4 0x00000000 0x3008C230 0x3008C220 0x300144A8
  0x30098F6C 0x00000001 0x3005AAC0 0x30098D18 0x30098F6C 0x3005AA1C
Pierre FICHEUX  -/- CTO OWI, France -\- pierre.ficheux at openwide.fr
                                          http://ingenierie.openwide.fr
                                          http://www.ficheux.org
I would love to change the world, but they won't give me the source code
