mvme167: "Can't get network memory"
rwas rbtwas at gmail.com
Thu Dec 27 03:24:17 UTC 2012
Joel Sherrill wrote:
>  Are you looking at the network-demos?
Yes, this is "netdemo" in network-demos.
>  There is a parameter to configure for number of mbufs.
I thought that was this: "CONFIGURE_MESSAGE_BUFFER_MEMORY".
There's a function to do it manually but I don't see how that's
different than the call the bsp makes.
Tracing the source code, I see this error message "Can't get network
memory" is generated right after
a "malloc()" call:
  in "rtems_glue.c"
  * Do the initializations required by the BSD code
static int
bsd_init (void)
         int i;
         char *p;
         p = rtems_bsdnet_malloc_mbuf(nmbuf * MSIZE + MSIZE -
1,MBUF_MALLOC_MBUF);
         p = (char *)(((uintptr_t)p + MSIZE - 1) & ~(MSIZE - 1));
         if (p == NULL) {
                 printf ("Can't get network memory.\n");
                 return -1;
and in:  "rtems_malloc_mbuf.c"
void* rtems_bsdnet_malloc_mbuf(size_t size, int type)
    return malloc(size);
So I'm wondering if I've over allocated or something.
One issue on the "CONIGURE" items is what units the memory size is in.
Someplace I saw that it was
in *kbytes* but elsewhere it appears to be in *bytes*. If it's in
*kbytes* I could easily have over allocated
elsewhere and not allowed anything for networking.
Robert W.
>  rwas <rbtwas at gmail.com> wrote:
>  Hello,
>  Anyway have network working on the mvme167?
>  I've tried a number of config options but  I keep getting the "Can't
>  get network memory" message.
>  Thanks.
>  Robert W.
>  config options used:
>  #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER #define
>  CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>  #define CONFIGURE_RTEMS_INIT_TASKS_TABLE #define
>  CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20 #define
>  CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>  #define CONFIGURE_EXECUTIVE_RAM_SIZE (512*1024)
>  // rwas #define CONFIGURE_MESSAGE_BUFFER_MEMORY             (32 *
>  1024) #define CONFIGURE_MAXIMUM_SEMAPHORES                 40 #define
>  CONFIGURE_MAXIMUM_TASKS                      30 #define
>  CONFIGURE_MAXIMUM_MESSAGE_QUEUES             30 #define
>  CONFIGURE_MAXIMUM_DRIVERS                    10
>  //#define CONFIGURE_MAXIMUM_SEMAPHORES 20 //#define
>  CONFIGURE_MAXIMUM_TASKS      20
>  // rwas #define CONFIGURE_MINIMUM_TASK_STACK_SIZE  (16 * 1024)
>  #define CONFIGURE_MEMORY_OVERHEAD                    4096 // in k
>  bytes
>  // rwas #define CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE 16384
>  #define CONFIGURE_MICROSECONDS_PER_TICK 10000
>  //#define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024) //#define
>  CONFIGURE_INIT_TASK_STACK_SIZE (64*1024) #define
>  CONFIGURE_INIT_TASK_STACK_SIZE (128*1024) #define
>  CONFIGURE_INIT_TASK_PRIORITY   120 #define
>  CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
>  RTEMS_NO_TIMESLICE | \ RTEMS_NO_ASR | \ RTEMS_INTERRUPT_LEVEL(0))
>  _______________________________________________ rtems-users mailing
>  list rtems-users at rtems.org
>  http://www.rtems.org/mailman/listinfo/rtems-users
