Problem in RTEMS Network initialization for MVME162 VME CPU Board
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Dec 3 15:12:33 UTC 2012
Hi
I was involved in the initial porting of that code from *BSD
to RTEMS. It is shared between the mvme162 and mvme167.
I recall we had luck on one but not the other.
Sorry but at this point, unless someone has a more recent
memory, you will need to debug it. It would be great to
get this working. :)
On the general configuration issues, I recommend moving
your app to a pc386 BSP (maybe using qemu) with a known
working configuration to make sure it isn't something you
are doing. Run one or more of the network demos on
the pc, then debug that app on the 162.
-joel
On 12/03/2012 04:19 AM, AJAI KUMAR MEDHAVI wrote:
> Hi
> I have developed an Application using RTEMS on MVME162 VME CPU Board. The
> Application consists of 4 Tasks with Priorities from 101 to 104.
> I have to test my RTEMS Application with another application running on
> Another PC through Ethernet (10 Mbps). Both the CPU board and another PC
> are
> interconnected though Hub.
> In RTEMS Init Task, I used the function
> rtems_bsdnet_initialize_network() to Initialize Networking. When I run my
> application on MVME162 CPU board, it hangs during Network Initialization.
> Printf is not working inside rtems_bsdnet_initialize_network().
> Please find the code for The RTEMS INIT Task , rtems_bsdnet_ifconfig&
> rtems_bsdnet_config structures initialization as given below :
> rtems_task Init(rtems_task_argument argument)
> rtems_status_code status;
> puts("\nRTEMS INIT TASK : Creating Application Resources .......\n" );
> /*-----Network initialization--------------------------------------------*/
> puts("\nNetwork initializing..........\n");
> rtems_bsdnet_initialize_network();
> puts("\nNetwork initialized!\n");
> /*-----Create Application Tasks Names------------------------------------*/
> APPINIT_TASK_NAME = rtems_build_name( 'T', 'A', '1', ' ' );
> RECV_TASK_NAME = rtems_build_name( 'T', 'A', '2', ' ' );
> RecvProcessTask_NAME = rtems_build_name( 'T', 'A', '3', ' ' );
> PeriodicReadTask_NAME = rtems_build_name( 'T', 'A', '4', ' ' );
> /*-----Create Application Semaphores / Message Queues
> ioread_sema_NAME = rtems_build_name( 'S', 'E', '1', ' ' );
> RecvProcessTask_msgQ_NAME = rtems_build_name( 'M', 'Q', '1', ' ' );
> PeriodicReadTask_msgQ_NAME = rtems_build_name( 'M', 'Q', '2', ' ' );
> /*-----Create Application Resources--------------------------------------*/
> create_app_tasks();
> create_app_msgqueues();
> create_app_sema();
> status = rtems_task_delete( RTEMS_SELF );
> directive_failed( status, "rtems_task_delete of RTEMS_SELF" );
> For Network Initialization, I have set my CPU Board IP address as
> 100.100.100.100 and configured following structures as given below :
> static struct rtems_bsdnet_ifconfig Appnetdriver_config = {
> RTEMS_BSP_NETWORK_DRIVER_NAME,
> RTEMS_BSP_NETWORK_DRIVER_ATTACH,
> NULL, /* link to next interface */
> "100.100.100.100", /* IP address */
> "255.255.255.0", /* IP net mask */
> NULL, /* hardware_address */
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> NULL
> struct rtems_bsdnet_config rtems_bsdnet_config = {
> &Appnetdriver_config, /* Network interface */
> NULL, /* Not use BOOTP to get network configuration */
> NETWORK_TASK_PRIORITY, /* Network task priority */
> 0, /* MBUF space */
> 0, /* MBUF cluster space */
> "rtems_host", /* Host name */
> 0, /* Domain name */
> 0, /* Gateway */
> "100.100.100.111", /* Log host */
> 0, /* Name server(s) */
> 0, /* NTP server(s) */
> 0,
> 0,
> 0,
> 0,
> 0
> The RTEMS_BSP_NETWORK_DRIVER_NAME and RTEMS_BSP_NETWORK_DRIVER_ATTACH has
> been defined in mvme16x_hw.h (in /c/src/lib/libbsp/m68k/shared/mvme/)as
> given below :
> struct rtems_bsdnet_ifconfig;
> int uti596_attach(struct rtems_bsdnet_ifconfig * pConfig, int attaching );
> #define RTEMS_BSP_NETWORK_DRIVER_NAME "uti1"
> #define RTEMS_BSP_NETWORK_DRIVER_ATTACH uti596_attach
> Please note that there is no problem if configure above two structures for
> Loopback test and loopback tests run perfectly.
> For RTEMS INIT task have also included following network files :
> #include<rtems/rtems_bsdnet.h>
> #include<rtems/error.h>
> #include<errno.h>
> #include<sys/socket.h>
> #include<netinet/in.h>
> Also defined :
> /*-------Init Task---------------------------------------------------*/
> #define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
> #define CONFIGURE_INIT_TASK_PRIORITY 50
> #define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
> RTEMS_NO_TIMESLICE | \
> RTEMS_NO_ASR | \
> RTEMS_INTERRUPT_LEVEL(0))
> /*-------Network Task Priorities----------*/
> #define NETWORK_TASK_PRIORITY 100
> /*-------Application Task Priorities------*/
> #define APPINIT_TASK_PRIORITY 101
> #define RecvProcessTask_PRIORITY 102
> #define Recv_Task_PRIORITY 103
> #define PeriodicReadTask_PRIORITY 104
> /*-------------- configuration
> information-------------------------------------------------------------------
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
> #define CONFIGURE_EXECUTIVE_RAM_SIZE (512*1024)
> #define CONFIGURE_MAXIMUM_SEMAPHORES 20
> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 20
> #define CONFIGURE_MAXIMUM_PERIODS 1
> #define CONFIGURE_MAXIMUM_TASKS 20
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_MICROSECONDS_PER_TICK 10000 /*--- Changed
> from 1000 to 10000 on July 11, 2012 ----------*/
> #define CONFIGURE_MAXIMUM_DRIVERS 10
> #define CONFIGURE_MAXIMUM_DEVICES 20
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 50
> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> Now I have to know following :
> 1. How to in initializing rtems_bsdnet_ifconfig& rtems_bsdnet_config
> structures ( MVME162 CPU Board IP address is 100.100.100.100 and This has
> to receive/send messages from/to another application running on Another PC
> through Ethernet (10 Mbps). Both the CPU board and another PC are
> interconnected though Hub )
> 2. Is there something wrong in the initialization of bsdnet config
> structures, I have done. If yes what will be proper values.
> 3.Whether I have to register Ethernet device driver in my application. If
> yes, the how ?
> 4.How to enable "Printf" inside rtems_bsdnet_initialize_network() just for
> debugging. The code inside "rtems_bsdnet_initialize_network()" have
> multiple printfs and probably has been disabled by some flag/Macros. I
> have not found the way how to enable printf and which
> file/makefile/configure file need to changed.
> Any suggestions/solutions at the earliest.
> Thanks in advance
> Best regards
> AJAI KUMAR MEDHAVI
> SCIENTIFIC OFFICER
> RAJA RAMMANNA CENTRE FOR ADVANCED TECHNOLGY
> DEPARTMENT OF ATOMIC ENERGY, GOV. OF INDIA,
> PO : CAT, INDORE-452013, INDIA
> PH. 91-731-2488052
> Email : akmedhavi at rrcat.gov.in , akmedhavi at rediffmail.com
