problem with rtems++ Timer & Interrupt class
Luca Cinquepalmi
cinquepalmi at planetek.it
Tue Dec 4 14:29:44 UTC 2012
I don't understand your answer very well... Can you give me more details?
Thanks a lot!
Luca
On 12/04/2012 03:26 PM, Gedare Bloom wrote:
> Check if printf is getting included in the new image and not in the
> old one. If for some reason those files pull in printf that can be a
> lot of extra code.
> On Tue, Dec 4, 2012 at 3:48 AM, Luca Cinquepalmi
> <cinquepalmi at planetek.it <mailto:cinquepalmi at planetek.it>> wrote:
> Hi all,
> I'm trying to compile rtems C++ source code with rtems provided class.
> I compile the following class without any problems:
> rtemsTask.cc
> rtemsSeamphore.cc
> rtemsMessageQueue.cc
> rtemsEvent.cc
> rtemsStatusCode.cc
> and the program perfectly works, but when I compile
> *rtemsInterrupt.cc* or *rtemsTimer.cc*
> the code is well compiled, but it doubles its dimension and
> doesn't work when loaded on my target board (LEON2).
> I'm using spar-rtems4.11-gcc as compiler.
> Did anyone have the same problem? Thanks!
> Luca
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
URL: <http://lists.rtems.org/pipermail/users/attachments/20121204/c23af642/attachment-0001.html>
