FAT Performance Optimizations
Gedare Bloom
gedare at rtems.org
Thu Dec 6 16:40:47 UTC 2012
Very impressive numbers! If I read right, on your test the PC->device
transfer rate went from about 646 KB/sec to 3834 KB/sec, and device->PC
went from 571 KB/sec to 5652 KB/sec
On Thu, Dec 6, 2012 at 10:59 AM, Ralf Kirchner <
ralf.kirchner at embedded-brains.de> wrote:
> Hi Users,
> I would like to share some good news.
> We have been successful in eliminating a few performance bottlenecks in
> the FAT file system. The FAT file system now writes by cluster instead
> of writing by sector. Also reading from the device during a file write
> has been minimized.
> As a result the data rate during a file write went up while the CPU
> usage (for example of the USB sub-system) went down.
> Here are some test results. The test setup is:
> A simple application loaded to the MPC8313ERDB evaluation board. The
> test application provides an ftp server and formats a USB memory stick
> with a FAT file system (with 64 sectors per cluster). Then it mounts the
> USB memory stick to /work/0 on the target.
> Then from a PC the program curl gets used to transfer data from the PC
> to the USB memory at the target respectively from the USB memory stick
> to the PC.
> Previous status (without the performance optimization):
> PC -> MPC8313ERDB
> curl -T /dev/zero ftp://anonymous@192.168.96.93/work/0/zero
> % Total % Received Xferd Average Speed Time Time Current
> Dload Upload Total Spent Speed
> 100 78.8M 0 0 78.8M 0 646k --:--:-- 0:02:04 438k
> MPC8313ERDB -> PC:
> curl -o /dev/null ftp://anonymous@192.168.96.93/work/0/zero
> 100 80.7M 100 80.7M 0 571k 0 0:02:24 0:02:24 567k
> With FAT optimizations:
> PC -> MPC8313ERDB
> 100 1290M 0 0 1290M 0 3834k --:--:-- 0:05:44 3914k
> [/work/0] # blkstats /dev/umass-sim-0-0
> DEVICE STATISTICS
> READ HITS | 96202
> READ MISSES | 328
> READ AHEAD TRANSFERS | 118
> READ BLOCKS | 788
> READ ERRORS | 0
> WRITE TRANSFERS | 1179
> WRITE BLOCKS | 18539
> WRITE ERRORS | 0
> MPC8313ERDB -> PC:
> 100 1291M 100 1291M 0 5652k 0 0:03:53 0:03:53 5900k
> DEVICE STATISTICS
> READ HITS | 767190
> READ MISSES | 7
> READ AHEAD TRANSFERS | 2663
> READ BLOCKS | 10663
> READ ERRORS | 0
> WRITE TRANSFERS | 1
> WRITE BLOCKS | 1
> WRITE ERRORS | 0
> The performance impact will vary depending mostly on your target system
> and on the configured number of sectors per cluster.
> Kind Regards
> Embedded Brains GmbH
> Ralf Kirchner Dornierstr. 4
> D-82178 Puchheim Germany
> email: ralf.kirchner at embedded-brains.de
> Phone: +49-89-18 94 741-17
> Fax: +49-89-18 94 741-08
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20121206/7edcfb10/attachment-0001.html>
