mvme167: "Can't get network memory"
Joel Sherrill Joel.Sherrill at OARcorp.com
Wed Dec 26 19:31:18 UTC 2012
Are you looking at the network-demos?
There is a parameter to configure for number of mbufs.
rwas <rbtwas at gmail.com> wrote:
Hello,
Anyway have network working on the mvme167?
I've tried a number of config options but  I keep getting the
"Can't get network memory" message.
Thanks.
Robert W.
config options used:
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
#define CONFIGURE_EXECUTIVE_RAM_SIZE (512*1024)
// rwas
#define CONFIGURE_MESSAGE_BUFFER_MEMORY             (32 * 1024)
#define CONFIGURE_MAXIMUM_SEMAPHORES                 40
#define CONFIGURE_MAXIMUM_TASKS                      30
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES             30
#define CONFIGURE_MAXIMUM_DRIVERS                    10
//#define CONFIGURE_MAXIMUM_SEMAPHORES 20
//#define CONFIGURE_MAXIMUM_TASKS      20
// rwas
#define CONFIGURE_MINIMUM_TASK_STACK_SIZE  (16 * 1024)
#define CONFIGURE_MEMORY_OVERHEAD                    4096 // in k bytes
// rwas
#define CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE 16384
#define CONFIGURE_MICROSECONDS_PER_TICK 10000
//#define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
//#define CONFIGURE_INIT_TASK_STACK_SIZE (64*1024)
#define CONFIGURE_INIT_TASK_STACK_SIZE (128*1024)
#define CONFIGURE_INIT_TASK_PRIORITY   120
#define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
                                            RTEMS_NO_TIMESLICE | \
                                            RTEMS_NO_ASR | \
                                            RTEMS_INTERRUPT_LEVEL(0))
rtems-users mailing list
rtems-users at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-users
