Bugzilla error
Daniel Hellstrom
daniel at gaisler.com
Wed Feb 8 15:31:01 UTC 2012
Hello,
When trying to create a new bugzilla PR I get the message below. It happens when I select product, both RTEMS and for Tools.
DBD::mysql::db selectall_arrayref failed: Unknown column 'reverse_desc' in 'field list' [for Statement "SELECT id,name,description,type,custom,mailhead,sortkey,obsolete,enter_bug,buglist,visibility_field_id,visibility_value_id,value_field_id,reverse_desc,is_mandatory FROM fielddefs WHERE custom = ? AND obsolete = ? ORDER BY sortkey, name"] at Bugzilla/Object.pm line 276
Bugzilla::Object::_do_list_select('Bugzilla::Field', 'custom = ? AND obsolete = ?', 'ARRAY(0x329fab8)', undef) called at Bugzilla/Object.pm line 253
Bugzilla::Object::match('Bugzilla::Field', 'HASH(0x30a5368)') called at Bugzilla/Field.pm line 258
Bugzilla::Field::match('Bugzilla::Field', 'HASH(0x30a5368)') called at Bugzilla.pm line 554
Bugzilla::active_custom_fields('Bugzilla') called at /usr/share/bugzilla/enter_bug.cgi line 401
For help, please send mail to the webmaster (root at localhost <mailto:root at localhost>), giving this error message and the time and date of the error.
When browsing existing bugs I get the message below.
Any ideas what might be wrong?
Daniel
Software error:
Table profile_search does not exist in the database schema. at Bugzilla/DB/Schema.pm line 1936.
