How to get the multi-lib options of a RTEMS installation
Ralf Corsepius ralf.corsepius at rtems.org
Fri Feb 10 03:05:45 UTC 2012
On 02/09/2012 05:44 PM, Sebastian Huber wrote:
> Hello,
> the RTEMS tool chain ships with so called multi-libs, e.g.
> find /opt/rtems-4.11/powerpc-rtems4.11/ -name libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/nof/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m7400/nof/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m7400/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m604/nof/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m604/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m403/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m505/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m860/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m8540/nof/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m8540/floatgprssingle/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m8540/floatgprsdouble/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m8540/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m8540/gprsdouble/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m603e/nof/libc.a
> /opt/rtems-4.11/powerpc-rtems4.11/lib/m603e/libc.a
> Is there a why to get the GCC options which were used to generate these
> multi-libs?
No. That's not how multilibs work.
The multilib directories are gcc internal default library search-paths,
GCC switches to when it finds certain combinations of flags in the
CFLAGS/LDFLAGS being passed to it.
I.e. there is a "multilib options" -> "multilibdir" transformation,
but there is no reverse transformation.
> This whould be nice for building libraries which depend only
> on POSIX interfaces.
I don't understand this question. Are you trying to build an RTEMS with
cpukit/posix enabled (or more general, with RTEMS cpukit specific flags
enabled) for some multilib variants and disabled for others and are
trying to install them into the default directories? In general, this
doesn't work.
Ralf
