RTEMS tool-chain | nm | strange behavior
Wendell Silva
silvawp at gmail.com
Thu Feb 16 19:09:41 UTC 2012
On more thing: sparc-rtems4.10-nm does not exhibit incorrect behavior. So,
chances are that the bug is limited to i386-rtems tool-chain.
Wendell.
2012/2/16 Wendell Silva <silvawp at gmail.com>
> Hello everybody,
> When calling:
> i386-rtems-4.10-nm --print-size --numeric-sort --line-numbers
> rtems-img.exe > rtems-img.num
> the list of symbols in the file rtems-img.num produces valid line numbers
> (location of the symbol in the source code) only for those at .text section.
> When the symbol is in .data (or .bss) it seems to be printed as it was in
> the location of the last symbol in the .text section, instead of the
> correct file/line number.
> Example of listing:
> (... suppressed lines ...)
> 001283f4 00000109 T lseek
> /home/developer/rtems-testing/rtems/build-i386-pc386-rtems/i386-rtems4.10/c/pc386/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/lseek.c:28
> 00128500 00000027 T _lseek_r
> /home/developer/rtems-testing/rtems/build-i386-pc386-rtems/i386-rtems4.10/c/pc386/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/lseek.c:98
> 00128528 00000012 T _malloc_r
> /home/developer/rtems-testing/rtems/build-i386-pc386-rtems/i386-rtems4.10/c/pc386/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/_malloc_r.c:26
> 0012853c 00000018 T _realloc_r
> /home/developer/rtems-testing/rtems/build-i386-pc386-rtems/i386-rtems4.10/c/pc386/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/_realloc_r.c:27
> 00128554 0000001e T _write_r
> /home/developer/rtems-testing/rtems/build-i386-pc386-rtems/i386-rtems4.10/c/pc386/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/write_r.c:37
> 00128574 0000000c T isatty
> /builddir/build/BUILD/rtems-4.10-i386-rtems4.10-gcc-4.4.5/build/i386-rtems4.10/newlib/libc/posix/../../../../../gcc-4.4.5/newlib/libc/posix/isatty.c:8
> 00128580 0000004f T _isatty
> /builddir/build/BUILD/rtems-4.10-i386-rtems4.10-gcc-4.4.5/build/i386-rtems4.10/newlib/libc/posix/../../../../../gcc-4.4.5/newlib/libc/posix/_isatty.c:10
> 001285d0 t __do_global_ctors_aux
> /builddir/build/BUILD/rtems-4.10-i386-rtems4.10-gcc-4.4.5/build/i386-rtems4.10/newlib/libc/posix/../../../../../gcc-4.4.5/newlib/libc/posix/_isatty.c:21
> 00128600 T __start_set_sysctl_set
> 00128600 A __stop_set_sysctl_set
> 00128600 T _init
> 0012860d T _fini
> 00128a04 00000018 R rtems_filesystem_table
> 00128a1c 00000010 R configuration_mount_table
> 00128a2c 00000004 R rtems_filesystem_mount_table_size
> The last three lines are incorrect.
> Look at "rtems_filesystem_table", for instance. It is expected to be
> allocated in the source that defines CONFIGURE_INIT, since it is in
> confdefs.h, however 'nm' thinks it is in _isatty.c, line 21 (!!!!).
> Can anyone confirm this strange behavior?
> Versions of nm and gcc I'm using:
> i386-rtems4.10-nm --version
> GNU nm (GNU Binutils) 2.20.1
> Copyright 2009 Free Software Foundation, Inc.
> This program is free software; you may redistribute it under the terms of
> the GNU General Public License version 3 or (at your option) any later
> version.
> This program has absolutely no warranty.
> i386-rtems4.10-gcc --version
> i386-rtems4.10-gcc (GCC) 4.4.5 20101001 (RTEMS
> gcc-4.4.5-4.fc14/newlib-1.18.0-19.fc14)
> Copyright (C) 2010 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions. There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> Thanks in advance,
> Att.
> Wendell Silva
Att.
Wendell P. Silva
+55 12 8114-8018
URL: <http://lists.rtems.org/pipermail/users/attachments/20120216/3e2c14c6/attachment.html>
