'CLOCK_THREAD_CPUTIME' undeclared
Mon Feb 27 17:22:32 UTC 2012
you might have better luck with the new VM at
http://wiki.rtems.org/wiki/index.php/Virtual_Machines_for_RTEMS_Development
the sourceforge image was probably uploaded awhile ago...
On Sun, Feb 26, 2012 at 7:39 AM, Fered <a_Fered at yahoo.com> wrote:
> On Yek-shanbe 07 Esfand 1390 11:36:48 Ralf Corsepius wrote:
>> On 02/26/2012 09:52 AM, Fered wrote:
>> > Hi;
>> > I'm using Fedora image, contains RTEMS11  and uploaded in sorceforge.
>> I don't understand what you are referring to, here.
>> > After doing instructions in rtems website, I have some errors.
>> > Log files are uploaded here:
>> > http://www.mediafire.com/?7q2h3oifa2qrol1
>> > Can anyone says me what's the problem?
>>  From your logs:
>> /home/rtems/rtems-4.11-work/rtems/c/src/../../cpukit/posix/src/clocksettime.
>> c: In function 'clock_settime':
>> c:48:25: error: 'CLOCK_PROCESS_CPUTIME' undeclared (first use in this
>> function) ...
>> CLOCK_PROCESS_CPUTIME was removed from the rtems-4.11 toolchains.
>> => You are facing an incompatibility between the RTEMS toolchains you
>> are using and the version of RTEMS you are trying to build
>> Ralf
> Thank you.
> I'm using toolchains, are installed on the image I dowloaded. Just I upgraded
> Fedora packages as the instructions in rtems website said:
> yum -y upgrade
> And after running bootstrap, it said "autoconf" and "automake" are old
> version. Thus I downloaded autoconf-2.68 and automake-1.11.3 from here:
> http://www.rtems.com/ftp/pub/rtems/SOURCES/4.11/
> and installed them.
> Is these new instalations, makes the error?
> rtems-users mailing list
> rtems-users at rtems.org
