'CLOCK_THREAD_CPUTIME' undeclared
Mon Feb 27 20:05:03 UTC 2012
Done. I deleted the link to the old images, which were being hosted in
a different sourceforge project page. Users should be grabbing the
Centos6.2 one that you spun last week.
On Mon, Feb 27, 2012 at 12:42 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Please fix the wiki page to point to the new images.
> I will delete the old ones when I get home.
> Gedare Bloom <gedare at rtems.org> wrote:
>>you might have better luck with the new VM at
>>http://wiki.rtems.org/wiki/index.php/Virtual_Machines_for_RTEMS_Development
>>the sourceforge image was probably uploaded awhile ago...
>>On Sun, Feb 26, 2012 at 7:39 AM, Fered <a_Fered at yahoo.com> wrote:
>>> On Yek-shanbe 07 Esfand 1390 11:36:48 Ralf Corsepius wrote:
>>>> On 02/26/2012 09:52 AM, Fered wrote:
>>>> > Hi;
>>>> > I'm using Fedora image, contains RTEMS11  and uploaded in sorceforge.
>>>> I don't understand what you are referring to, here.
>>>> > After doing instructions in rtems website, I have some errors.
>>>> > Log files are uploaded here:
>>>> > http://www.mediafire.com/?7q2h3oifa2qrol1
>>>> > Can anyone says me what's the problem?
>>>>  From your logs:
>>>> /home/rtems/rtems-4.11-work/rtems/c/src/../../cpukit/posix/src/clocksettime.
>>>> c: In function 'clock_settime':
>>>> c:48:25: error: 'CLOCK_PROCESS_CPUTIME' undeclared (first use in this
>>>> function) ...
>>>> CLOCK_PROCESS_CPUTIME was removed from the rtems-4.11 toolchains.
>>>> => You are facing an incompatibility between the RTEMS toolchains you
>>>> are using and the version of RTEMS you are trying to build
>>>> Ralf
>>> Thank you.
>>> I'm using toolchains, are installed on the image I dowloaded. Just I upgraded
>>> Fedora packages as the instructions in rtems website said:
>>> yum -y upgrade
>>> And after running bootstrap, it said "autoconf" and "automake" are old
>>> version. Thus I downloaded autoconf-2.68 and automake-1.11.3 from here:
>>> http://www.rtems.com/ftp/pub/rtems/SOURCES/4.11/
>>> and installed them.
>>> Is these new instalations, makes the error?
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
